hello,
using latest alpha release.
i created a modeless form, and added one TextBox, one GraphicButton (for closing the form) on it. i tried to handle the ReturnPressed event for the TextBox. it seems to work. but the form always gets closed when "ENTER" key is pressed inside the TextBox. if i press "SPACE" or "ENTER" again on AutoCAD command line, the form will reappear.
another thing i noticed was the form height will be "automatically" changed. the TitleBar property of this form is set to False. i wanted to set the Height property for both the TextBox and Form to 20. and it looked fine when i did so. but after i save, close and reopen the .odcl file, the form height has changed to 34. i might have reported this problem before.
thanks.
