Author Topic: Reactor Question?  (Read 5590 times)
Reactor Question?
« on: December 07, 2006, 05:37:51 PM »
I put this in the acaddoc.lsp expecting it to fire & run the (axl2qt-sub) when the DWG loading
process is finished but it doesn't fire. What did  I miss?
;; Set up the Reactor
(if (= (type Quan_Table_Reactor) 'VLR-DWG-Reactor)
  (if (not (vlr-added-p Quan_Table_Reactor))
    (vlr-add Quan_Table_Reactor)
  (setq Quan_Table_Reactor (vlr-dwg-reactor nil '((:vlr-endDwgOpen . axl2qt-rea))))
;; call back function
(defun axl2qt-rea (reactor callbackData)
(print "***  Reactor Fired  ***")
  ;;  disable the reactor, only used firt time in DWG
  ;(vlr-remove Quan_Table_Reactor)
  (or axl2qt-sub (load "Excel Read test0010.LSP"))
  (axl2qt-sub) ; call the routine to buid the table.
« Last Edit: December 07, 2006, 05:38:53 PM by CAB »
Re: Reactor Question?
« Reply #1 on: December 07, 2006, 06:20:06 PM »
OK, I got this one to fire when switching between open drawings,
but i want it to fire when the drawing opens for the first time.
  (setq Quan_Table_Reactor (vlr-docmanager-reactor nil '((:vlr-documentBecameCurrent . axl2qt-rea))))
  ;(or axl2qt-sub (load "Excel Read test0010.LSP"))
 (test_rea)
(defun test_rea ()
  (print " Oh Happy Days.")
« Reply #2 on: December 07, 2006, 06:22:52 PM »
I don't think you can Alan, at least not in lisp.  You might have to make a VBA routine.  My logic is, once you open the drawing, it will be active already, before the lisp loads, so it will never fire again until you lose the active'ness of it.  Does that make any sense?
« Reply #3 on: December 07, 2006, 06:31:40 PM »
Yes, but I don't like it.  :oops:
« Reply #4 on: December 07, 2006, 06:32:23 PM »
I will do some testing when I can, and see if I can get one to load upon opening.
« Reply #5 on: December 07, 2006, 06:37:34 PM »
OK, I found it in one of Luis's codes.
(setq Quan_Table_Reactor (vlr-docmanager-reactor nil '((:vlr-documentLockModeWillChange . axl2qt-rea))))
« Reply #6 on: December 07, 2006, 06:39:24 PM »
I don't think you will be able to do what you want Alan.  I think you would need to open the drawing once and make the reactor, and then open it again, and then it will fire.  Maybe you can make a 'command will start' reactor for the very first command, and then in the reactor call back, have it remove it, so that it will only fire once per drawing.
Just thinking out loud.
Edit:  I see you found something while I was typing.  Hope it works the way you want it to.
« Last Edit: December 07, 2006, 06:40:58 PM by T.Willey »
« Reply #7 on: December 07, 2006, 07:33:30 PM »
Yes, this works when you put this in the acaddoc.lsp
As soon as the DWG is finished opening it fires.
 ; (axl2qt-sub) ; call the routine to buid the table.
 (test_rea)
(defun test_rea ()
  (print " Oh Happy Days.\n")
PS: Hold on, still has problem. Will advise.
« Last Edit: December 07, 2006, 07:54:00 PM by CAB »
« Reply #8 on: December 07, 2006, 08:09:19 PM »
Well with this version it fires 3 times during the open process.
(if (= (type Quan_Table_Reactor) 'vlr-dwg-reactor)
           nil
           '((:vlr-documentlockmodewillchange . axl2qt-rea))
  ;; (vlr-remove Quan_Table_Reactor)
  ;(axl2qt-sub) ; call the routine to buid the table.
CDG Change Case loaded - type "CDGCASE" to run
Command:
CDG Purge 3.0 loaded
"CDGPURGE" - dialog interface
"-CDGPURGE" - command line interface
Command:
AutoCAD Express Tools Copyright © 2000 Autodesk, Inc.
Offset Loaded. Enter OFS to run.
SlideDisplay.LSP for AutoCAD is loaded.
To view a slide one of the following commands:
WCS=Window Call Sizes VSF=Fraction/Decimal Chart
   <<Ignored AutoCAD 2005 Variable List>>
   <<Ignored AutoCAD 2004 Variable List>>
   <<Ignored AutoCAD 2002 Variable List>>
   <<Ignored AutoCAD 2000i Variable List>>
ACADSet_Variables has set system variables to your preset values.
AutoCAD menu utilities loaded.
AutoCAD menu utilities loaded.  DDMODIFY loaded.
Command:
DOSLib Version 6.1.4 (Feb 12 2004)
Copyright © 1992-2004, Robert McNeel & Associates
Plot2000 - www.plot2000.com
Plot2000 loaded. Commands are: PLOT2000CONFIG, BATCHPLOT, OKTEST!
Command:
"***  Reactor Fired  ***" *Cancel*
Chris
« Reply #9 on: December 08, 2006, 07:17:30 AM »
Alan,
I have no Idea what the command is that fires to produce this line
Autodesk DWG.  This file is a Trusted DWG last saved by an Autodesk application or Autodesk licensed application.
but it appears to always be the last thing done before control is returned to the reducer.  If it can be determined what this command is, you can issue a commandended reactor to fire axl2qt.  I will try looking into it and see if I can find anything.  Maybe someone else knows what command is being called.
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
« Reply #10 on: December 08, 2006, 07:55:24 AM »
Thanks Chris and welcome to the Swamp. :-)
kpblc
« Reply #11 on: December 08, 2006, 08:59:56 AM »
Can be, try to load a reactor not in acaddoc.lsp, and into a separate file which and to load automatically?
Sorry for my English.
« Reply #12 on: December 08, 2006, 09:36:38 AM »
Well it didn't like that. 8-)
I put the file in the "startup suite"
Command:
"***  Reactor Fired  ***" Command:
Command:
Command:
« Last Edit: December 08, 2006, 09:38:08 AM by CAB »
« Reply #13 on: December 08, 2006, 10:39:44 AM »
Well thanks to Chris who came up with the reactor that worked.
I can now move on to finding out what you can & can not do in a call back routine. :)
           nil
           '((:vlr-documentToBeActivated  . axl2qt-rea))
« Reply #14 on: December 08, 2006, 11:11:37 AM »
From what I remember, no calls to 'command' whatever, and no asking for user input.
