Author Topic: Name the process :: Game 1  (Read 8234 times)
« on: May 10, 2006, 08:45:08 AM »
The object of this game is to name the process you want done on this function. The first one to post, gets to name the overall process preformed. Then we have to build our procedures based on those instructions. For instance; here is a sample game played out.
*** POST 1
Given the list: (0 1 2 3 4 5 6 7 8 9)
I want to ___________.
*** POST 2
Return the list with he last item removed.
*** POST 3
(defun pop-last (l)
  (reverse (cdr (reverse l))) )
(Obviously, thats a very simple example, but im not going to build a complex example for something that im not entirely sure is going to 'fly'.) I think this game could be alot of fun because of the lack of direction (so to speak) You are free to do as you want without restraints.
So...
Given the list: (0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9)
uncoolperson
Re: Name the process :: Game 1
« Reply #1 on: May 10, 2006, 10:11:33 AM »
dent it up real good?
list unique?
(create a list of lists of unique values from a list of not so unique values)
« Reply #2 on: May 10, 2006, 11:49:13 AM »
What?!
uncoolperson
« Reply #3 on: May 10, 2006, 12:38:24 PM »
i did it once... and i forgot what i did to make it pretty...
turn a list like;
(1 2 3 4 5 4 4 2 1 3 6 7 4 6 9 6 5 1 3)
into
(( 1 2 3 4 5 6 7 9 ) ( 1 2 3 4 5 6 ) ( 1 3 4 6 ) ( 4 ))
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: May 11, 2006, 08:55:44 AM »
(defun for-theswamp (lst)
  (if lst
    ((lambda (x)
       (cons (vl-sort (car x) '<) (for-theswamp (cadr x)))
     ) ;_  lambda
      (for-theswamp-1 (cdr lst) (list (car lst)) nil)
  ) ;_  if
) ;_  defun
(defun for-theswamp-1 (lst a1 a2)
  (if lst
    (if (member (car lst) a1)
      (for-theswamp-1 (cdr lst) a1 (cons (car lst) a2))
      (for-theswamp-1 (cdr lst) (cons (car lst) a1) a2)
    ) ;_  if
    (list a1 a2)
  ) ;_  if
) ;_  defun
(for-theswamp  '(1 2 3 4 5 4 4 2 1 3 6 7 4 6 9 6 5 1 3))
;; => '((1 2 3 4 5 6 7 9) (1 2 3 4 5 6) (1 3 4 6) (4))
uncoolperson
« Reply #5 on: May 11, 2006, 10:22:05 AM »
i thought i had killed this
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #6 on: May 11, 2006, 10:36:35 AM »
I have not understood you...
I have written this program today.
« Reply #7 on: May 11, 2006, 11:18:41 AM »
AS I understand uncoolperson comment, I think he was saying that he killed the thread due to the lack of activity.
I just think people are too busy to participate, anyway that's my excuse.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: May 11, 2006, 12:54:50 PM »
Thank for explanations Alan :-)
« Reply #9 on: May 11, 2006, 01:06:07 PM »
You are welcome.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #10 on: May 11, 2006, 01:33:28 PM »
You are welcome.
If, my course...
Sort the list which is not using SETQ, VL-*
(setq lst '(7 3 4 6 9 6 7 2 5 3 2 3 6 4 6 3 1)
      f   (function <)
(defun sort (lst f)
« Reply #11 on: May 11, 2006, 01:44:50 PM »
(defun sort (lst)
  (dos_sortlist lst)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #12 on: May 11, 2006, 01:47:29 PM »
Shortly, but for me does not work... :-(
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: May 11, 2006, 01:49:30 PM »
(defun sort (lst)
  (dos_sortlist lst)
For this program, it is necessary dos_lib?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #14 on: May 12, 2006, 01:42:52 PM »
Probably, I have not understood, game rules...
Where I can see or explain me.
Beforehand thank!
