Author Topic: Name the process :: Game 1  (Read 8059 times)
Re: Name the process :: Game 1
« Reply #15 on: May 12, 2006, 02:46:22 PM »
ElpanovEvgeniy
I think you got it.
You started with a hard one. I tried for about 15 minutes but no easy solution.
Perhaps you can post your solution.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #16 on: May 12, 2006, 02:57:23 PM »
ElpanovEvgeniy
I think you got it.
Version 1
(defun rec-min (lst mi f)
  ;(rec-min (cdr lst) (car lst) f)
    ((not lst) mi)
    (((eval f) (car lst) mi)
    (t (rec-min (cdr lst) mi f))
  ) ;_  cond
) ;_  defun
(defun rec-remove-singl (i lst)
  ;(rec-remove-singl (cadr lst) lst)
  (if lst
    (if (equal i (car lst))
      (cdr lst)
      (cons (car lst) (rec-remove-singl i (cdr lst)))
    ) ;_  if
  ) ;_  if
) ;_  defun
(defun rec-sort-min (lst f)
  ;(rec-sort-min lst)
  (if lst
    ((lambda (x)
       (cons
         x
         (rec-sort-min
           (rec-remove-singl
             x
             lst
           f
     ) ;_  lambda
  ) ;_  if
) ;_  defun
  ; Check:
(setq lst '(7 3 4 6 9 6 7 2 5 3 2 3 6 4 6 3 1)
      f   (function <)
) ;_  setq
(rec-sort-min lst f)
Version 2
(defun rec-min-max (lst mi ma f)
    ((not lst) (list mi ma))
     (rec-min-max (cdr lst) (car lst) ma f)
    (((eval f) ma (car lst))
     (rec-min-max (cdr lst) mi (car lst) f)
    (t (rec-min-max (cdr lst) mi ma f))
  ) ;_  cond
) ;_  defun
  (if lst
      (cdr lst)
    ) ;_  if
  ) ;_  if
) ;_  defun
(defun rec-sort-min-max (lst f)
    ((not lst) nil)
    ((not(cdr lst)) lst)
    (t
     ((lambda (x)
        (cons
          (car x)
          (append
            (rec-sort-min-max
              (rec-remove-singl
                (car x)
                (rec-remove-singl
                  (cadr x)
                  lst
                ) ;_  rec-remove-singl
              f
            ) ;_  rec-sort-lists
            (cdr x)
          ) ;_  append
        ) ;_  cons
      ) ;_  lambda
       (rec-min-max (cdr lst) (car lst) (car lst) f)
  ) ;_  cond
) ;_  defun
  ; Check:
      f   (function <)
) ;_  setq
(rec-sort-min-max lst f)
Version 3
(defun rec-quicksort-2 (lst lst1 lst2 test f)
    ((not lst)
      (list lst1 (list test) lst2)
    (((eval f) (car lst) test)
     (rec-quicksort-2 (cdr lst) (cons (car lst) lst1) lst2 test f)
    (t (rec-quicksort-2 (cdr lst) lst1 (cons (car lst) lst2) test f))
  ) ;_  cond
) ;_  defun
(defun rec-quicksort-1 (lst f)
    ((not lst) nil)
    ((not (car lst)) (rec-quicksort-1 (cdr lst) f))
    ((not (cdar lst))
     (cons (caar lst) (rec-quicksort-1 (cdr lst) f))
    ((not (cddar lst))
     (if (apply f (car lst))
       (cons (caar lst) (cons (cadar lst) (rec-quicksort-1 (cdr lst) f)))
       (cons (cadar lst) (cons (caar lst) (rec-quicksort-1 (cdr lst) f)))
     ) ;_  if
    (t
     ((lambda (x)
        (rec-quicksort-1 (cons (car x) (cons (cadr x) (cons (caddr x) (cdr lst)))) f)
      ) ;_  lambda
       (rec-quicksort-2 (cdar lst) nil nil (caar lst) f)
  ) ;_  cond
) ;_  defun
(defun rec-quicksort (lst f)
  (rec-quicksort-1 (list lst) f)
) ;_  defun
  ; Check:
      f   (function <)
) ;_  setq
(rec-quicksort lst f)
ElpanovEvgeniy
  • Moscow (Russia)
« Last Edit: May 12, 2006, 03:29:36 PM by ElpanovEvgeniy »
« Reply #18 on: May 12, 2006, 05:26:34 PM »
No wonder I was having trouble figuring it out. :)
Thanks for the link, I'll do some reading. Just need more time....
