Author Topic: The name game :: Object Snaps  (Read 7093 times)
CADaver
Re: The name game :: Object Snaps
« Reply #30 on: May 03, 2006, 10:49:27 PM »
OSNAP searches the area enclosed by the APERTURE, and will select the feature nearest the intersection of the crosshairs that satisfies the osnap condition.
Sdoman
« Reply #31 on: May 03, 2006, 11:09:14 PM »
Many times when you want to Osnap to the INSertion point of a block that contains lots of attributes, AutoCAD will snap to the attribute insertion points instead of the blocks insertion point (they should have given text objects a unique osnap).  You can avoid this by preceding your INSertion osnap with a QUIck osnap.
This can been done by typing at the command prompt QUI,INS using a comma to separate the osnaps.  Or it can also be done one snap at a time by using a toolbar or menu:  QUI<Enter>INS<Enter>.
[fixed typo]
[another typo <g> ]
« Last Edit: May 04, 2006, 08:17:56 AM by Steve Doman »
Bryco
« Reply #32 on: May 04, 2006, 12:09:32 AM »
fro (from) can be used in conjunction w/ osnaps and while it does cool thangs it's too confusing to bother with (I hope it's only me that doesn't bother with it)
Shinyhead
« Reply #33 on: May 04, 2006, 07:18:24 AM »
Well.... :-P
I use fro and o'snaps in macros to give me control of how a routine works without needing lisp, its actually very handy. But for general command line usage no, its kind of a pain. ;-)
Shinyhead
« Reply #34 on: May 04, 2006, 07:19:41 AM »
Many times when you want to Osnap to the INSertion point of a block that contains lots of of attributes, AutoCAD will snap to the attribute insertion points instead of the blocks insertion point (they should have given text objects a unique osnap).  You can avoid this by preceding your INSertion osnap with a QUIck osnap.
This can been down by typing at the command prompt QUI,INS using a comma to separate the osnaps.  Or it can also be done one snap at a time by using a toolbar or menu:  QUI<Enter>INS<Enter>.
[fixed typo]
That is something I am gonna have to play with, I have had issues with that of late.
Chuck Gabriel
« Reply #35 on: May 04, 2006, 08:02:04 AM »
This little gem predates the addition of the "from" functionality, but I still prefer it.  I'm sorry to say I have no idea who the original author is.  I'm sure someone here probably knows, since I've seen this routine in use in more than one office.
;;; This is a useful routine for obtaining a relative point.
;;; It can be used whenever an AutoCAD command requests a point.
;;; Just enter "(ref)" in response to the "...point:" prompt, and
;;; enter the desired base (reference) point and the relative/polar
;;; offset from that point.
(defun ref ()
  (getpoint (getpoint "\nSelect base point. ")
    "\nEnter offset or drag direction and select distance: "
SDETERS
« Reply #36 on: May 04, 2006, 08:13:50 AM »
If you are a autocad user and do not use osnaps and have .001 or so gaps between all of your objects I am sure you would be drug out in the street and shot by the next person who works on your drawing!   :pissed:
Sdoman
« Reply #37 on: May 04, 2006, 08:26:31 AM »
The QUIck osnap isn't listed on AutoCAD's menus any more, so I am sure a lot of users don't know about it or have forgotten about it.  It is used as a modifier to the osnap that follows it.   Another situation where QUIck is useful, is when osnaping to entities embedded in large Xrefs.
Bryco
« Reply #38 on: May 04, 2006, 09:14:49 AM »
mtp or m2p is a new osnap-middle point between two points
CADaver
« Reply #39 on: May 04, 2006, 05:56:39 PM »
(defun ref ()
I wrote this in 1987:
(defun ro ()  (getpoint (getpoint "\nReference point: ") "\nOffset from reference: "))
Along with this APPINT workaround
(defun ip (/ line1 line2 list1 list2)
    (setq line1 (entsel "\nSelect first line: ")
  line2 (entsel "\nSelect second line: ")
  list1 (entget (car line1))
  list2 (entget (car line2))
    (inters (cdr (assoc 10 list1)) (cdr (assoc 11 list1)) (cdr (assoc 10 list2)) (cdr (assoc 11 list2)) nil)
VerticalMojo
« Reply #40 on: May 11, 2006, 12:49:35 PM »
Often a saying used when something comes at a shock or out of nowhere.
For example: O' snap! That guy just ran a red light!
                                        or
                   O' snap! You just got dissed by that girl!
For more examples see the movie Zoolander.....
