Is there a tutorail for setting up slides for inserting blocks. Since moving to Arizonia I've seen several companies that have thier blocks set up as a dialog box with slides that when you click on one of the slides that block will insert. My new boss has mentioned setting up each preview as a slide, then image manager to set up a dialog box, but my Cad book does not get in much depth with slides, creating dialog boxs or image manager. If it helps what I am after is very similiar to what "Blockman" looks like. I've had a few replies, but I'm not looking to spend $50-$100
