Quote from: domenicomaria on August 21, 2023, 09:42:47 AMit's not perfect, (because it doesn't analyze curves but only segments), LM:ent->pts builds approximations for curves, so it's better than you think
Quote from: domenicomaria on August 21, 2023, 11:16:44 AMQuote from: Marc'Antonio Alessi on August 21, 2023, 10:39:05 AMPlease post your sample DWG.
See replay #1 and #11...
Here is an exact solution for polylines.It is a mathematical solution, no entity is changed at all.
@DEXUSQuoteHere is an exact solution for polylines.It is a mathematical solution, no entity is changed at all.It works perfectly !you are very good !
I would love to take credit, but it should be @Stefan
I think Stefan will fail if reference entity is INSERT...I've included all that's possible in my BBox.lsp... It'll try even with nested inserts that overlap each other...
Quote from: ribarm on August 22, 2023, 03:56:31 AMI think Stefan will fail if reference entity is INSERT...I've included all that's possible in my BBox.lsp... It'll try even with nested inserts that overlap each other...The code of Stefan is only for polylines ...
