Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Do I really need error checking
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Do I really need error checking (Read 1050 times)
jlogan02
Bull Frog
on:
December 13, 2022, 06:01:18 PM »
This routine doesn't have any user actions to it except selecting a button that launches the routine. Is there really any reason for error checking for routines that don't have user action required within the code?
Code - Auto/Visual Lisp:
[Select]
defun
c:ST01ToBy
*error*
msg col
defun
*error*
msg
if
not
member
msg '
"Function cancelled"
"quit / exit abort"
princ
strcat
\n
Error: "
msg
princ
setvar
'cmdecho
0
if
setq
col
ssget
"X"
0
"*Dimension,MultiLeader,Hatch,*Line,*Text,Arc,Circle"
62
1
foreach
x
mapcar
cadr
ssnamex
col
entmod
append
entget
x
62
256
command
"_layer"
"Make"
"LINE1"
"color"
"yellow"
"LINE1"
setvar
'cmdecho
1
princ
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
mhupp
Bull Frog
Re: Do I really need error checking
Reply #1 on:
December 14, 2022, 08:46:14 AM »
Always a potential for an error. you can set variables back to what they were before the lisp was called, or undo changes. the code isn't run unless their is an error so whats the harm?
[Select]
defun
c:ST01ToBy
*error*
msg col
defun
*error*
msg
if
not
member
msg '
"quit / exit abort"
princ
strcat
\n
Error: "
msg
vla-endundomark
Drawing
command
"_U"
;undo if error
setvar
'cmdecho
1
;set cmdecho back to one if their is an ERROR
princ
setq
Drawing
vla-get-activedocument
vlax-get-acad-object
vla-startundomark
Drawing
setvar
'cmdecho
0
if
setq
col
ssget
"X"
0
62
1
foreach
x
mapcar
cadr
ssnamex
col
entmod
append
entget
x
62
256
;(command "_layer" "Make" "LINE1" "color" "yellow" "LINE1" "")
entmake
0
"LAYER"
100
"AcDbSymbolTableRecord"
100
"AcDbLayerTableRecord"
2
"LINE1"
70
0
62
2
setvar
'cmdecho
1
vla-endundomark
Drawing
princ
Last Edit: December 15, 2022, 11:10:25 PM by mhupp
Logged
jlogan02
Bull Frog
Reply #2 on:
December 14, 2022, 06:43:43 PM »
Good point. It can' t hurt.
Logged
J. Logan
ACAD 2018
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Reply #3 on:
December 14, 2022, 07:01:35 PM »
Just be careful where you place the 'undo'.
Haven't tested, but I think the 'undo' in your handler will override the setvar ( a couple lines earlier )
Logged
Called Kerry in my other life
I live at UTC + 13.00
jlogan02
Bull Frog
Reply #4 on:
December 15, 2022, 05:20:35 PM »
Thanks. I'll double check.
Logged
J. Logan
ACAD 2018
mhupp
Bull Frog
Reply #5 on:
December 15, 2022, 11:56:54 PM »
Thanks kdub code updated.
--Edit
Also ran into this the other day. In BricsCAD you can just run the ssget with out an if statement and it wouldn't error if nil. sent a lisp to someone running AutoCAD and it does error if nil. It also had an error trap so nothing was coming up.
They kept typing the command a couple more times. until they asked me why it wasn't working.
so while not displaying the default error maybe display a coustom one like.
[Select]
defun
*error*
msg
if
not
member
msg '
"quit / exit abort"
princ
strcat
\n
Error: "
msg
princ
\n
Something Went Wrong Contact: Name Here"
vla-endundomark
Drawing
command
"_U"
;undo if error
setvar
'cmdecho
1
princ
Last Edit: December 16, 2022, 11:56:56 AM by mhupp
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
