Author Topic: Do I really need error checking  (Read 1197 times)
jlogan02
« on: December 13, 2022, 06:01:18 PM »
This routine doesn't have any user actions to it except selecting a button that launches the routine. Is there really any reason for error checking for routines that don't have user action required within the code?
  1. (defun c:ST01ToBy (/ *error* msg col )
  2.
  3.   (defun *error* (msg)
  4.
  5.     (if (not (member msg '("Function cancelled" "quit / exit abort")))
  6.       (princ (strcat "\nError: " msg))
  7.     )
  8.     (princ)
  9.   )
  10.
  11.   (setvar 'cmdecho 0)
  12.
  13.   (if
  14.     (setq col (ssget "X" '((0 . "*Dimension,MultiLeader,Hatch,*Line,*Text,Arc,Circle") (62 . 1))))
  15.     (foreach x (mapcar 'cadr (ssnamex col))
  16.         (entmod (append (entget x) '((62 . 256)))))
  17.   )
  18.
  19.    (command "_layer" "Make" "LINE1" "color" "yellow" "LINE1" "")
  20.
  21.   (setvar 'cmdecho 1)
  22.
  23.  (princ)
  24. )
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
mhupp
Re: Do I really need error checking
« Reply #1 on: December 14, 2022, 08:46:14 AM »
Always a potential for an error. you can set variables back to what they were before the lisp was called, or undo changes. the code isn't run unless their is an error so whats the harm?
  1. (defun c:ST01ToBy (/ *error* msg col)
  2.   (defun *error* (msg)
  3.     (if (not (member msg '( "Function cancelled" "quit / exit abort")))
  4.       (princ (strcat "\nError: " msg))
  5.     )
  6.     (vla-endundomark Drawing)
  7.     (command "_U") ;undo if error
  8.     (setvar 'cmdecho 1) ;set cmdecho back to one if their is an ERROR
  9.     (princ)
  10.   )
  11.   (vla-startundomark Drawing)
  12.   (setvar 'cmdecho 0)
  13.   (if (setq col (ssget "X" '((0 . "*Dimension,MultiLeader,Hatch,*Line,*Text,Arc,Circle") (62 . 1))))
  14.     (foreach x (mapcar 'cadr (ssnamex col))
  15.       (entmod (append (entget x) '((62 . 256))))
  16.     )
  17.   )
  18.   ;(command "_layer" "Make" "LINE1" "color" "yellow" "LINE1" "")
  19.   (entmake '((0 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2 . "LINE1") (70 . 0) (62 . 2)))
  20.   (setvar 'cmdecho 1)
  21.   (vla-endundomark Drawing)
  22.   (princ)
  23. )
« Last Edit: December 15, 2022, 11:10:25 PM by mhupp »
jlogan02
« Reply #2 on: December 14, 2022, 06:43:43 PM »
Good point. It can' t hurt.
J. Logan
ACAD 2018
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #3 on: December 14, 2022, 07:01:35 PM »
Just be careful where you place the 'undo'.
Haven't tested, but I think the 'undo' in your handler will override the setvar ( a couple lines earlier )
Called Kerry in my other life
I live at UTC + 13.00
jlogan02
« Reply #4 on: December 15, 2022, 05:20:35 PM »
Thanks. I'll double check.
J. Logan
ACAD 2018
mhupp
« Reply #5 on: December 15, 2022, 11:56:54 PM »
Thanks kdub code updated.
--Edit
Also ran into this the other day. In BricsCAD you can just run the ssget with out an if statement and it wouldn't error if nil. sent a lisp to someone running AutoCAD and it does error if nil.  It also had an error trap so nothing was coming up.
They kept typing the command a couple more times. until they asked me why it wasn't working.
so while not displaying the default error maybe display a coustom one like.
  1. (defun *error* (msg)
  2.   (if (not (member msg '( "Function cancelled" "quit / exit abort")))
  3.     (princ (strcat "\nError: " msg))
  4.     (princ "\nSomething Went Wrong Contact: Name Here")
  5.   )
  9.   (princ)
  10. )
« Last Edit: December 16, 2022, 11:56:56 AM by mhupp »
