Author Topic: vl-string-left-trim  (Read 8089 times)
GDF
vl-string-left-trim
« on: December 14, 2019, 02:07:46 PM »
I can't seem to get this to work properly:
(substr (vl-filename-base (getvar "dwgname")) 1 16)
result = "190240 256830086"
(substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 30))
result = "190240 256830086 4420 Sugargrove Ln"
(vl-string-left-trim (substr (vl-filename-base (getvar "dwgname")) 1 16)
        (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 30)))
result = "Sugargrove Ln"
result should be = "4420 Sugargrove Ln"
ribarm
  • Marko Ribar, architect
Re: vl-string-left-trim
« Reply #1 on: December 14, 2019, 02:34:45 PM »
You should try instead :
(substr (vl-filename-base (getvar "dwgname")) 17)
(vl-string-left/right-trim) is known with this behavior to remove additional characters that are found in pattern string... To me even (vl-string-trim) is not 100% reliable... The best choice is to try to avoid them and use ordinary (substr) function...
M.R. on Youtube
roy_043
  • BricsCAD 18
« Reply #2 on: December 14, 2019, 03:19:19 PM »
The first argument of the vl-string-left-trim function is not a pattern but a character set. So what the OP is seeing is the correct bahavior.
GDF
« Reply #3 on: December 14, 2019, 04:02:22 PM »
I think I have found the problem.
When I rename the file, I get the vl-string-left-trim error.
Other wise it works ok.
I'm using BricsCAD
« Reply #4 on: December 14, 2019, 05:01:59 PM »
Note that this behaviour is not an error, nor is it an issue with the apparent 'reliability' of the vl-string-*-trim functions. The vl-string-left-trim function is operating exactly as designed and described by the documentation, removing all characters which appear in the supplied character set argument.
In the given example posted by GDF, the character set is:
"190240 256830086"
Therefore, the vl-string-left-trim function will remove all occurrences of the characters " ","0","1","2","3","4","5","6","8","9" from the left of the string, until a character is reached which is not a member of this set.
Applied to the string:
This correctly returns the result:
"Sugargrove Ln"
As the characters " ", "0", "2" & "4" are a member of the character set.
This discussion is very similar to this recent thread.
GDF
« Reply #5 on: December 14, 2019, 09:15:22 PM »
Sorry, I'm still confused
Example one: (file has been renamed with 190240 as part of the file Name)
190240 256830086 4420 Sugargrove Ln L10 B05 3013 TXW YR V3.dwg
Example two:  (original file 190239 as part of the file Name)
190239 256830086 4420 Sugargrove Ln L10 B05 3013 TXW YR V3
result = "190239 256830086"
result = "190239 256830086 4420 Sugargrove Ln"
result = "4420 Sugargrove Ln"
;;;Victor Delgado  VDelgado@alhansen.com
(defun ARCH:UpdateBlocks  (BlockName AttTag AttVal / ssBlocks ssObjects Block)
  (setq ssBlocks (ssget "x" (list (cons 2 BlockName))))
  (if ssBlocks
    (progn (setq ssObjects
                  (vla-get-ActiveSelectionSet
                    (vla-get-ActiveDocument (vlax-get-acad-object))))
           (vlax-for
                  Block  ssObjects
             (foreach
                    Attribute  (vlax-invoke Block "GetAttributes")
               (if (= (vla-get-TagString Attribute) AttTag)
                 (vla-put-TextString Attribute AttVal))
               (vla-update Attribute)))))
  (princ))
(ARCH:UpdateBlocks "DRHortonTBH" "ADD" (vl-string-left-trim (substr (vl-filename-base (getvar "dwgname")) 1 16)
        (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 27))))
« Last Edit: December 14, 2019, 09:38:06 PM by GDF »
ribarm
« Reply #6 on: December 15, 2019, 12:15:23 AM »
It is perfectly fine - look in your second example :
Char set : "190239 256830086" don't contain number 4, so left trimming is fine - first char from left is 4 : "4420 Sugargrove Ln"
But as I stated before, if you know this numbers marked red :
I would suggest that you use more confident - just simple :
(substr (getvar 'dwgname) 17 (- 30 16))
M.R. on Youtube
roy_043
  • BricsCAD 18
« Reply #7 on: December 15, 2019, 04:09:51 AM »
Maybe use this instead:
(vl-string-subst "" "ab" "ababc") => "abc"
GDF
« Reply #8 on: December 15, 2019, 07:28:25 AM »
Thanks everyone for the help!
GDF
« Reply #9 on: December 15, 2019, 08:35:35 AM »
Because the address is of different lengths in the drawing file names.
I got the following to work in all cases:
(substr (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 27)) 18)
I was going about it the wrong way using vl-string-left-trim.
Thanks again.
GDF
« Reply #10 on: December 15, 2019, 11:41:46 AM »
This is my updated code, that propagates the titleblock attributes based upon the drawing file name.
(defun C:TBUP (/ client subdiv city)
  ;;(command ".qsave")
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "DRHNO" (getstring T "\n* Enter DRH #: \"3013 XL V? R?\""))
    ((/= (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 1) 1) "R")
      (ARCH:UpdateBlocks "DRHortonTBH" "DRHNO" (strcat (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 13) 5)
        (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 4) 5))))
    ((= (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 1) 1) "R")
      (ARCH:UpdateBlocks "DRHortonTBH" "DRHNO" (strcat (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 16) 5)
        (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 7) 8)))))
  (ARCH:UpdateBlocks "DRHortonTBH" "DATE" (ARCH:C_DATE-ISSUE (getvar "tdupdate")))
  (ARCH:UpdateBlocks "DRHortonTBH" "BPSNO" (vl-Filename-Base (vl-Filename-Directory (getvar "DwgPrefix"))))
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "PLANNO" (strcat "PLAN " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 17) 14)))
      (ARCH:UpdateBlocks "DRHortonTBH" "PLANNO" (strcat "PLAN " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 17) 14))))
      (ARCH:UpdateBlocks "DRHortonTBH" "PLANNO" (strcat "PLAN " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 20) 17)))))
  (ARCH:UpdateBlocks "DRHortonTBH" "JOBNO" (substr (vl-filename-base (getvar "dwgname")) 8 9))
  (setq client (getstring T "\n* Enter Residence Client:"))
    ((/= client "")(ARCH:UpdateBlocks "DRHortonTBH" "RES" client))
    ((= client "")(ARCH:UpdateBlocks "DRHortonTBH" "RES" "RESIDENCE")))
  (setq client nil)
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "SUB" (getstring T "\n* Enter Subdivision:"))
  (setq subdiv (getstring T "\n* Enter Subdivison:"))
    ((/= subdiv "")(ARCH:UpdateBlocks "DRHortonTBH" "SUB" subdiv))
    ((= subdiv "")(ARCH:UpdateBlocks "DRHortonTBH" "SUB" "Highcroft Estates, Phase 1")))
  (setq subdiv nil)
      (ARCH:UpdateBlocks "DRHortonTBH" "LB" (strcat "LOT " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 24) 2)
        ", BLOCK " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 20) 2))))
      (ARCH:UpdateBlocks "DRHortonTBH" "LB" (strcat "LOT " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 27) 2)
        ", BLOCK " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 23) 2)))))
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "ADD" (vl-string-left-trim (substr (vl-filename-base (getvar "dwgname")) 1 16)(substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 27))))
      (ARCH:UpdateBlocks "DRHortonTBH" "ADD" (substr (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 27)) 18)))
      (ARCH:UpdateBlocks "DRHortonTBH" "ADD" (substr (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 30)) 18))))
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "CITY" (getstring T "\n* Enter City State:"))
  (setq city (getstring T "\n* Enter City State:"))
    ((/= city "")(ARCH:UpdateBlocks "DRHortonTBH" "CITY" city))
    ((= city "")(ARCH:UpdateBlocks "DRHortonTBH" "CITY" "Arlington, TX 76001")))
  (setq city nil)
  (ARCH:MsgBox1
    " Arch2Program© : Message"
    64
    (strcat
      "DR Horton Titleblock Updated Successfully"
    2
  (princ))
« Reply #11 on: December 15, 2019, 12:24:38 PM »
I can't help thinking there's an abbreviated version begging to be outed. Is it possible to get a representative sample of dwg names?
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
GDF
« Reply #12 on: December 15, 2019, 01:06:16 PM »
Michael, see previous post above...
190240 256830086 1234 Anystreet Drive L10 B05 3013 TXW YR V3 R2.dwg
« Last Edit: December 15, 2019, 01:10:57 PM by GDF »
« Reply #13 on: December 15, 2019, 01:24:41 PM »
Thanks GDF.
Would the rev number (assuming that's what it represents) ever be more than 1 digit or alpha numerical?
"190240 256830086 1234 Anystreet Drive L10 B05 3013 TXW YR V3 R12.dwg"
"190240 256830086 1234 Anystreet Drive L10 B05 3013 TXW YR V3 R1A.dwg"
"190240 256830086 1234 Anystreet Drive L10 B05 3013 TXW YR V3 R12A.dwg"
GDF
« Reply #14 on: December 15, 2019, 01:38:17 PM »
No
