Author Topic: vl-string-left-trim  (Read 8087 times)
GDF
vl-string-left-trim
« on: December 14, 2019, 02:07:46 PM »
I can't seem to get this to work properly:
(substr (vl-filename-base (getvar "dwgname")) 1 16)
result = "190240 256830086"
(substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 30))
result = "190240 256830086 4420 Sugargrove Ln"
(vl-string-left-trim (substr (vl-filename-base (getvar "dwgname")) 1 16)
        (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 30)))
result = "Sugargrove Ln"
result should be = "4420 Sugargrove Ln"
ribarm
  • Marko Ribar, architect
Re: vl-string-left-trim
« Reply #1 on: December 14, 2019, 02:34:45 PM »
You should try instead :
(substr (vl-filename-base (getvar "dwgname")) 17)
(vl-string-left/right-trim) is known with this behavior to remove additional characters that are found in pattern string... To me even (vl-string-trim) is not 100% reliable... The best choice is to try to avoid them and use ordinary (substr) function...
M.R. on Youtube
roy_043
  • BricsCAD 18
« Reply #2 on: December 14, 2019, 03:19:19 PM »
The first argument of the vl-string-left-trim function is not a pattern but a character set. So what the OP is seeing is the correct bahavior.
GDF
« Reply #3 on: December 14, 2019, 04:02:22 PM »
I think I have found the problem.
When I rename the file, I get the vl-string-left-trim error.
Other wise it works ok.
I'm using BricsCAD
« Reply #4 on: December 14, 2019, 05:01:59 PM »
Note that this behaviour is not an error, nor is it an issue with the apparent 'reliability' of the vl-string-*-trim functions. The vl-string-left-trim function is operating exactly as designed and described by the documentation, removing all characters which appear in the supplied character set argument.
In the given example posted by GDF, the character set is:
"190240 256830086"
Therefore, the vl-string-left-trim function will remove all occurrences of the characters " ","0","1","2","3","4","5","6","8","9" from the left of the string, until a character is reached which is not a member of this set.
Applied to the string:
This correctly returns the result:
"Sugargrove Ln"
As the characters " ", "0", "2" & "4" are a member of the character set.
This discussion is very similar to this recent thread.
GDF
« Reply #5 on: December 14, 2019, 09:15:22 PM »
Sorry, I'm still confused
Example one: (file has been renamed with 190240 as part of the file Name)
190240 256830086 4420 Sugargrove Ln L10 B05 3013 TXW YR V3.dwg
Example two:  (original file 190239 as part of the file Name)
190239 256830086 4420 Sugargrove Ln L10 B05 3013 TXW YR V3
result = "190239 256830086"
result = "190239 256830086 4420 Sugargrove Ln"
result = "4420 Sugargrove Ln"
;;;Victor Delgado  VDelgado@alhansen.com
(defun ARCH:UpdateBlocks  (BlockName AttTag AttVal / ssBlocks ssObjects Block)
  (setq ssBlocks (ssget "x" (list (cons 2 BlockName))))
  (if ssBlocks
    (progn (setq ssObjects
                  (vla-get-ActiveSelectionSet
                    (vla-get-ActiveDocument (vlax-get-acad-object))))
           (vlax-for
                  Block  ssObjects
             (foreach
                    Attribute  (vlax-invoke Block "GetAttributes")
               (if (= (vla-get-TagString Attribute) AttTag)
                 (vla-put-TextString Attribute AttVal))
               (vla-update Attribute)))))
  (princ))
(ARCH:UpdateBlocks "DRHortonTBH" "ADD" (vl-string-left-trim (substr (vl-filename-base (getvar "dwgname")) 1 16)
        (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 27))))
« Last Edit: December 14, 2019, 09:38:06 PM by GDF »
ribarm
« Reply #6 on: December 15, 2019, 12:15:23 AM »
It is perfectly fine - look in your second example :
Char set : "190239 256830086" don't contain number 4, so left trimming is fine - first char from left is 4 : "4420 Sugargrove Ln"
But as I stated before, if you know this numbers marked red :
I would suggest that you use more confident - just simple :
(substr (getvar 'dwgname) 17 (- 30 16))
M.R. on Youtube
roy_043
  • BricsCAD 18
« Reply #7 on: December 15, 2019, 04:09:51 AM »
Maybe use this instead:
(vl-string-subst "" "ab" "ababc") => "abc"
GDF
« Reply #8 on: December 15, 2019, 07:28:25 AM »
Thanks everyone for the help!
GDF
« Reply #9 on: December 15, 2019, 08:35:35 AM »
Because the address is of different lengths in the drawing file names.
I got the following to work in all cases:
(substr (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 27)) 18)
I was going about it the wrong way using vl-string-left-trim.
Thanks again.
GDF
« Reply #10 on: December 15, 2019, 11:41:46 AM »
This is my updated code, that propagates the titleblock attributes based upon the drawing file name.
(defun C:TBUP (/ client subdiv city)
  ;;(command ".qsave")
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "DRHNO" (getstring T "\n* Enter DRH #: \"3013 XL V? R?\""))
    ((/= (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 1) 1) "R")
      (ARCH:UpdateBlocks "DRHortonTBH" "DRHNO" (strcat (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 13) 5)
        (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 4) 5))))
    ((= (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 1) 1) "R")
      (ARCH:UpdateBlocks "DRHortonTBH" "DRHNO" (strcat (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 16) 5)
        (substr (getvar "dwgname")(- (strlen (vl-filename-base (getvar "dwgname"))) 7) 8)))))
  (ARCH:UpdateBlocks "DRHortonTBH" "DATE" (ARCH:C_DATE-ISSUE (getvar "tdupdate")))
  (ARCH:UpdateBlocks "DRHortonTBH" "BPSNO" (vl-Filename-Base (vl-Filename-Directory (getvar "DwgPrefix"))))
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "PLANNO" (strcat "PLAN " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 17) 14)))
      (ARCH:UpdateBlocks "DRHortonTBH" "PLANNO" (strcat "PLAN " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 17) 14))))
      (ARCH:UpdateBlocks "DRHortonTBH" "PLANNO" (strcat "PLAN " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 20) 17)))))
  (ARCH:UpdateBlocks "DRHortonTBH" "JOBNO" (substr (vl-filename-base (getvar "dwgname")) 8 9))
  (setq client (getstring T "\n* Enter Residence Client:"))
    ((/= client "")(ARCH:UpdateBlocks "DRHortonTBH" "RES" client))
    ((= client "")(ARCH:UpdateBlocks "DRHortonTBH" "RES" "RESIDENCE")))
  (setq client nil)
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "SUB" (getstring T "\n* Enter Subdivision:"))
  (setq subdiv (getstring T "\n* Enter Subdivison:"))
    ((/= subdiv "")(ARCH:UpdateBlocks "DRHortonTBH" "SUB" subdiv))
    ((= subdiv "")(ARCH:UpdateBlocks "DRHortonTBH" "SUB" "Highcroft Estates, Phase 1")))
  (setq subdiv nil)
      (ARCH:UpdateBlocks "DRHortonTBH" "LB" (strcat "LOT " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 24) 2)
        ", BLOCK " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 20) 2))))
      (ARCH:UpdateBlocks "DRHortonTBH" "LB" (strcat "LOT " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 27) 2)
        ", BLOCK " (substr (getvar "dwgname")(- (strlen (getvar "dwgname")) 23) 2)))))
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "ADD" (vl-string-left-trim (substr (vl-filename-base (getvar "dwgname")) 1 16)(substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 27))))
      (ARCH:UpdateBlocks "DRHortonTBH" "ADD" (substr (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 27)) 18)))
      (ARCH:UpdateBlocks "DRHortonTBH" "ADD" (substr (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 30)) 18))))
  ;;(ARCH:UpdateBlocks "DRHortonTBH" "CITY" (getstring T "\n* Enter City State:"))
  (setq city (getstring T "\n* Enter City State:"))
    ((/= city "")(ARCH:UpdateBlocks "DRHortonTBH" "CITY" city))
    ((= city "")(ARCH:UpdateBlocks "DRHortonTBH" "CITY" "Arlington, TX 76001")))
  (setq city nil)
  (ARCH:MsgBox1
    " Arch2Program© : Message"
    64
    (strcat
      "DR Horton Titleblock Updated Successfully"
    2
  (princ))
« Reply #11 on: December 15, 2019, 12:24:38 PM »
I can't help thinking there's an abbreviated version begging to be outed. Is it possible to get a representative sample of dwg names?
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
GDF
« Reply #12 on: December 15, 2019, 01:06:16 PM »
Michael, see previous post above...
190240 256830086 1234 Anystreet Drive L10 B05 3013 TXW YR V3 R2.dwg
« Last Edit: December 15, 2019, 01:10:57 PM by GDF »
« Reply #13 on: December 15, 2019, 01:24:41 PM »
Thanks GDF.
Would the rev number (assuming that's what it represents) ever be more than 1 digit or alpha numerical?
"190240 256830086 1234 Anystreet Drive L10 B05 3013 TXW YR V3 R12.dwg"
"190240 256830086 1234 Anystreet Drive L10 B05 3013 TXW YR V3 R1A.dwg"
"190240 256830086 1234 Anystreet Drive L10 B05 3013 TXW YR V3 R12A.dwg"
GDF
« Reply #14 on: December 15, 2019, 01:38:17 PM »
No
« Reply #15 on: December 15, 2019, 02:23:39 PM »
Ok thanks.
On a different note, this quick and dirty stab (coded blind so I don't know if it works) is how I might structure the code so there's less repetition of logic and it's more discernible / maintainable (subjective := yes):
(defun C:TBUP ( / add:val base:len base:name bps:no city client date drh:no dwg:len dwg:name dwg:prefix job:no lb:val plan:no subdiv )
    (setq
        dwg:prefix (getvar 'dwgprefix)
        bps:no     (vl-filename-base (vl-filename-directory dwg:prefix))
        dwg:name   (getvar 'dwgname)
        dwg:len    (strlen dwg:name)
        base:name  (vl-filename-base dwg:name)
        base:len   (strlen base:name)
        job:no     (substr base:name 8 9)
        client     (vl-string-trim " " (getstring T "\n* Enter Residence Client:"))
        client     (if (eq "" client) "RESIDENCE" client)
        subdiv     (vl-string-trim " " (getstring T "\n* Enter Subdivison:"))
        subdiv     (if (eq "" subdiv) "Highcroft Estates, Phase 1")
        city       (vl-string-trim " " (getstring T "\n* Enter City State:"))
        city       (if (eq "" city) "Arlington, TX 76001" city)
        date       (ARCH:C_DATE-ISSUE (getvar "tdupdate"))
    ;;  Assumes rev number is always a single digit.
    (if (wcmatch (strcase base:name) "*R#")
        (setq
            drh:no  (strcat (substr dwg:name (- base:len 16) 5) (substr dwg:name (- base:len  7) 8))
            plan:no (strcat "PLAN " (substr dwg:name (- dwg:len 20) 17))
            lb:val  (strcat "LOT "  (substr dwg:name (- dwg:len 27) 2) ", BLOCK " (substr dwg:name (- dwg:len 23) 2))
            add:val (substr (substr dwg:name 1 (- dwg:len 30)) 18)
        (setq
            drh:no  (strcat (substr dwg:name (- base:len 13) 5) (substr dwg:name (- base:len  4) 5))
            plan:no (strcat "PLAN " (substr dwg:name (- dwg:len 17) 14))
            lb:val  (strcat "LOT "  (substr dwg:name (- dwg:len 24) 2) ", BLOCK " (substr dwg:name (- dwg:len 20) 2))
            add:val (substr (substr dwg:name 1 (- dwg:len 27)) 18)
    (foreach pair
        (mapcar 'cons
           '("DRHNO" "PLANNO" "ADD" "LB" "DATE" "BPSNO" "JOBNO" "RES" "SUB" "CITY")
            (list drh:no plan:no add:val lb:val date bps:no job:no client subdiv city)
        (ARCH:UpdateBlocks "DRHortonTBH" (car pair) (cdr pair))
    (ARCH:MsgBox1
        64 ;; bit coded var for dialog style?
        (strcat "DR Horton Titleblock Updated Successfully")
        2  ;; bit coded var for icon style?
For what it's worth, cheers.
« Last Edit: December 15, 2019, 05:14:08 PM by MP »
ribarm
« Reply #16 on: December 15, 2019, 02:38:00 PM »
@MP, I think you missed :
(setq dwg:name (getvar 'dwgname))
There may be something I haven't noticed, but anyway very well coded...
M.R. on Youtube
« Reply #17 on: December 15, 2019, 02:43:14 PM »
Indeed, fixed and thanks ribarm.
GDF
« Reply #18 on: December 15, 2019, 03:01:52 PM »
WOW
Thanks...this will keep me busy and out of trouble for a long time digesting your code.
« Reply #19 on: December 15, 2019, 03:09:43 PM »
You're welcome sir.
PS: I noticed some other distillage that could be performed (res, sub, city) and revised it accordingly.
Cheers.
GDF
« Reply #20 on: December 15, 2019, 03:38:34 PM »
Thank you again MASTER CODER, I mean MP. It's remarkable that you could write this code without being able to test it. My hat's off to you.
(defun C:TBMP ( / client subdiv city dwg:prefix dwg:name dwg:len base:name base:len drh:no plan:no add:val lb:val )
    (setq
        parent:folder (vl-filename-base (vl-filename-directory dwg:prefix))
        (setq
            ;;plan:no (strcat "PLAN " (substr dwg:name (- dwg:len 17) 14))
            lb:val  nil ;; not needed but makes intention clear
        (setq
            ;;plan:no (strcat "PLAN " (substr dwg:name (- dwg:len 20) 17))
    (ARCH:UpdateBlocks "DRHortonTBH" "DRHNO"  drh:no)
    (ARCH:UpdateBlocks "DRHortonTBH" "PLANNO" plan:no)
    (ARCH:UpdateBlocks "DRHortonTBH" "ADD"    add:val)
    (if lb:val (ARCH:UpdateBlocks "DRHortonTBH" "LB" lb:val))
    (ARCH:UpdateBlocks "DRHortonTBH" "BPSNO" parent:folder)
    (ARCH:UpdateBlocks "DRHortonTBH" "JOBNO" job:no)
    (if (eq "" (vl-string-trim " " (setq client (getstring T "\n* Enter Residence Client:"))))
    (if (eq "" (setq subdiv (vl-string-trim " " (getstring T "\n* Enter Subdivison:"))))
    (if (eq "" (setq city (vl-string-trim " " (getstring T "\n* Enter City State:"))))
    (ARCH:MsgBox1
« Last Edit: December 15, 2019, 03:53:44 PM by GDF »
« Reply #21 on: December 15, 2019, 05:23:36 PM »
You're most welcome sir.
PS:
  • Updated code to reflect correction of index errors you flagged.
  • Plus one I believe you missed.
  • Did final refactoring.
Cheers.
GDF
« Reply #22 on: December 15, 2019, 06:51:03 PM »
 :smitten:
« Reply #23 on: December 15, 2019, 07:08:34 PM »
Was fun + your response made it golden.
Still room for improving the string slicing, dicing but honey-do list abounds.
Cheers. :-)
GDF
« Reply #24 on: December 16, 2019, 08:03:39 AM »
Hey, I have hundreds of more poorly written code that need a little house cleaning... :2funny:
 :smitten:
« Reply #25 on: December 16, 2019, 09:21:34 AM »
First crystal meth sample is always free. :evil:
GDF
« Reply #26 on: December 16, 2019, 10:05:38 AM »
Your rewriting of the code thru progressing stages would be an great teaching aid!
I have learned a lot from your progressive coding technique! Thank you, and I hope others can learn from this exercise.
« Reply #27 on: December 16, 2019, 10:11:22 AM »
It’s funny you mentioned that. When you said “I have hundreds ...” I thought “send me a dozen worthy candidates - I’ll revise one of them if you allow me to publish an article about the refactoring of same”. Obviously any proprietary info would have to be removed or obfuscated.
Anyway, thanks so much for your kind words, music to me.
GDF
« Reply #28 on: December 16, 2019, 10:30:39 AM »
Here is a messy floor sq ft code based upon getting the area of a hatch.
It' in bad shape...but works for me.
;; EN   entity name of insert
;; TAG  attribute tag
;; NEW  new attribute value [string]
;; Replaces current attribute value stored in
;; drawing with the NEW string value.
(defun ARCH:ATTUPDATE  (EN TAG NEW / EL)
  (setq EN (entnext EN)
        ;;skip INSERT
        EL (entget EN)
           ;;get ATTRIB
  ;; Search attribs for match of tag name
  (while (and (= (cdr (assoc 0 EL)) "ATTRIB") (/= (cdr (assoc 2 EL)) TAG))
          ;;next ATTRIB
          EL (entget EN)))
  (if (= (cdr (assoc 0 EL)) "ATTRIB")
    (progn (entmod ;;modify entity data
                   (subst ;;substitute in list
                          (cons 1 NEW)
                          ;;new data
                          (assoc 1 EL)
                          ;;old data
                          EL
                          ;;list
           (entupd EN)
           ;;force regen of entity
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Area Calulation Table ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun C:SFT22  (/ lo ss)
  (setq lo (getvar "ctab"))
  (if (/= (getvar "ctab") "Model")(setvar "ctab" "Model"))
  (setvar "attreq" 0)
  (C:ONN)
  ;;(setq ss (ssget "_X" '((0 . "insert") (2 ."SHT_FloorAreaDRHorton"))))
  ;;(if ss (entdel (ssname ss 0)))
  (setq ss (ssget "X" '((2 . "SHT_FloorAreaDRHorton"))))
  (if (/= ss nil)(command "erase" ss ""))
  (if (/= ss nil)(command "-purge" "block" ss "no"))
  (ARCH:LYR "A-SYMB-CALC")
  (if (/= (ssget "A" '((0 . "HATCH") (8 . "AREA-HEAT-1ST"))) nil)
    (progn (setq ARCH#DECI "0")
             (SFT-TOTL-it)))
    (prompt "\n** No Area calculations for: Square Footage **"))
  (setvar "ctab" lo)
  (princ))
(defun SFT-TOTL-it  (/ areasch en obj sfobj totur totac totsb note tmp totliv HEAT-1STsf HEAT-2NDsf GROS-1STsf GROS-2NDsf GARGsf PORCsf PATOsf)
  (setvar "cmdecho" 0)
  (command
           "-insert"
           (strcat "SHT_FloorAreaDRHorton" "=" ARCH#CUSF ARCH#_SYM  "Arch_syms\\"
           "ps"
           (getvar "dimscale")
           "0,0"
           1
           1
           0
  (setq areasch (entlast))
  (setq en (cdr (assoc -1 (entget areasch))))
    (progn (setq HEAT-1ST
                  (cdr
                    (assoc -1
                           (entget (ssname (ssget "A" '((0 . "HATCH") (8 . "AREA-HEAT-1ST"))) 0)))))
           (command "AREA" "o" HEAT-1ST)
           (setq HEAT-1STsf (/ (getvar "AREA") 144))
           (ARCH:ATTUPDATE en "HEAT-1ST" (strcat "" (rtos (/ (getvar "AREA") 144) 2 (atoi ARCH#DECI)) " SF"))))
  (if (/= (ssget "A" '((0 . "HATCH") (8 . "AREA-HEAT-2ND"))) nil)
    (progn (setq HEAT-2ND
                  (cdr
                    (assoc -1
                           (entget (ssname (ssget "A" '((0 . "HATCH") (8 . "AREA-HEAT-2ND"))) 0)))))
           (command "AREA" "o" HEAT-2ND)
           (setq HEAT-2NDsf (/ (getvar "AREA") 144))
           (ARCH:ATTUPDATE en "HEAT-2ND" (strcat "" (rtos (/ (getvar "AREA") 144) 2 (atoi ARCH#DECI)) " SF"))))
  (if (/= (ssget "A" '((0 . "HATCH") (8 . "AREA-GROS-1ST"))) nil)
    (progn (setq GROS-1ST
                  (cdr
                    (assoc -1
                           (entget (ssname (ssget "A" '((0 . "HATCH") (8 . "AREA-GROS-1ST"))) 0)))))
           (command "AREA" "o" GROS-1ST)
           (setq GROS-1STsf (/ (getvar "AREA") 144))
           (ARCH:ATTUPDATE en "GROS-1ST" (strcat "" (rtos (/ (getvar "AREA") 144) 2 (atoi ARCH#DECI)) " SF"))))
  (if (/= (ssget "A" '((0 . "HATCH") (8 . "AREA-GROS-2ND"))) nil)
    (progn (setq GROS-2ND
                  (cdr
                    (assoc -1
                           (entget (ssname (ssget "A" '((0 . "HATCH") (8 . "AREA-GROS-2ND"))) 0)))))
           (command "AREA" "o" GROS-2ND)
           (setq GROS-2NDsf (/ (getvar "AREA") 144))
           (ARCH:ATTUPDATE en "GROS-2ND" (strcat "" (rtos (/ (getvar "AREA") 144) 2 (atoi ARCH#DECI)) " SF"))))
  (if (/= (ssget "A" '((0 . "HATCH") (8 . "AREA-BALC"))) nil)
    (progn (setq BALC
                  (cdr
                    (assoc -1
                           (entget (ssname (ssget "A" '((0 . "HATCH") (8 . "AREA-BALC"))) 0)))))
           (command "AREA" "o" BALC)
           (setq BALCsf (/ (getvar "AREA") 144))
           (ARCH:ATTUPDATE en "BALC" (strcat "" (rtos (/ (getvar "AREA") 144) 2 (atoi ARCH#DECI)) " SF"))))
  (if (/= (ssget "A" '((0 . "HATCH") (8 . "AREA-GARG"))) nil)
    (progn (setq GARG
                  (cdr
                    (assoc -1
                           (entget (ssname (ssget "A" '((0 . "HATCH") (8 . "AREA-GARG"))) 0)))))
           (command "AREA" "o" GARG)
           (setq GARGsf (/ (getvar "AREA") 144))
           (ARCH:ATTUPDATE en "GARG" (strcat "" (rtos (/ (getvar "AREA") 144) 2 (atoi ARCH#DECI)) " SF"))))
  (if (/= (ssget "A" '((0 . "HATCH") (8 . "AREA-PORC"))) nil)
    (progn (setq PORC
                  (cdr
                    (assoc -1
                           (entget (ssname (ssget "A" '((0 . "HATCH") (8 . "AREA-PORC"))) 0)))))
           (command "AREA" "o" PORC)
           (setq PORCsf (/ (getvar "AREA") 144))
           (ARCH:ATTUPDATE en "PORC" (strcat "" (rtos (/ (getvar "AREA") 144) 2 (atoi ARCH#DECI)) " SF"))))
  (if (/= (ssget "A" '((0 . "HATCH") (8 . "AREA-PATO"))) nil)
    (progn (setq PATO
                  (cdr
                    (assoc -1
                           (entget (ssname (ssget "A" '((0 . "HATCH") (8 . "AREA-PATO"))) 0)))))
           (command "AREA" "o" PATO)
           (setq PATOsf (/ (getvar "AREA") 144))
           (ARCH:ATTUPDATE en "PATO" (strcat "" (rtos (/ (getvar "AREA") 144) 2 (atoi ARCH#DECI)) " SF"))))
  (progn (if (= HEAT-1STsf nil)(setq HEAT-1STsf 0.0))
         (if (= HEAT-2NDsf nil)(setq HEAT-2NDsf 0.0))
         (if (= GROS-1STsf nil)(setq GROS-1STsf 0.0))
         (if (= GROS-2NDsf nil)(setq GROS-2NDsf 0.0))
         (if (= BALCsf nil)(setq BALCsf 0.0))
         (if (= GARGsf nil)(setq GARGsf 0.0))
         (if (= PORCsf nil)(setq PORCsf 0.0))
         (if (= PATOsf nil)(setq PATOsf 0.0)))
  (setq totur (strcat (rtos (+ GROS-1STsf GROS-2NDsf GARGsf PORCsf PATOsf) 2 (atoi ARCH#DECI)) " SF"))
  (setq totac (strcat (rtos (+ HEAT-1STsf HEAT-2NDsf) 2 (atoi ARCH#DECI)) " SF"))
  (setq totliv (strcat (rtos (+ GROS-1STsf GROS-2NDsf) 2 (atoi ARCH#DECI)) " SF"))
  (setq totsb (strcat (rtos (+ GROS-1STsf GARGsf PORCsf PATOsf) 2 (atoi ARCH#DECI)) " SF"))
  (if (/= totliv nil)(ARCH:ATTUPDATE en "TOTLIV" totliv))
  (if (/= totur nil)(ARCH:ATTUPDATE en "TOTUR" totur))
  (if (/= totac nil)(ARCH:ATTUPDATE en "TOTAC" totac))
  (if (/= totsb nil)(ARCH:ATTUPDATE en "TOTSB" totsb))
  (command "copy" areasch "" '(0.0 0.0 0.0) '(1632.0 0.0 0.0))
  (princ))
GDF
« Reply #29 on: December 16, 2019, 11:00:06 AM »
Here is another one that will make you slap your forehead, see attached file for setting up dimstyles.
« Reply #30 on: December 17, 2019, 10:13:33 PM »
Check your mailbox sir.  I sent a pm early yesterday morning and another today. Thanks + cheers.
