Author Topic: Export to PDF issues  (Read 5084 times)
snownut2
  • Bricscad 22 Ultimate
« on: July 11, 2019, 03:22:31 AM »
Any one else having with export to PDF not working right.  PDF files won't open in Adobe reader.
  • (x-in)->[process]->(y-out)
Re: Export to PDF issues
« Reply #1 on: July 11, 2019, 03:54:06 AM »
Just tried in V19, no problems there, what version are you using?
"The E in Javascript stands for 'easy'." — Florin Pop tweet
snownut2
« Reply #2 on: July 11, 2019, 11:05:10 AM »
V19 - 64bit
If I print through a pdf printer all is good, but when i try to Export to PDF its junk.
Any chance you could send me a screen shot of how you have export settings set.
« Reply #3 on: July 11, 2019, 06:31:35 PM »
I normally use pdf-creator to print to pdf but after trying it out yesterday I may change, it's very fast!
I don't know how to not print model space though...
my settings
Peter2
« Reply #4 on: July 12, 2019, 07:50:15 AM »
... but when i try to Export to PDF its junk....
can you upload an example?
Peter
AutoCAD Map 3D 2018 / 2023 German (so some technical terms will be badly retranslated to English)
BricsCAD V22
snownut2
« Reply #5 on: July 12, 2019, 07:37:08 PM »
Sure, here's one, this won't open correctly in Adobe, but opens fine in Foxit.
Peter2
« Reply #6 on: July 14, 2019, 05:41:56 AM »
.... but opens fine in Foxit.
And in PDF XChange Viewer and Editor too ..
Peter
BricsCAD V22
