Author Topic: Export to PDF issues  (Read 3748 times)
snownut2
  • Bricscad 22 Ultimate
« on: July 11, 2019, 03:22:31 AM »
Any one else having with export to PDF not working right.  PDF files won't open in Adobe reader.
MickD
  • (x-in)->[process]->(y-out)
Re: Export to PDF issues
« Reply #1 on: July 11, 2019, 03:54:06 AM »
Just tried in V19, no problems there, what version are you using?
Forth is like the Tao: it is a Way, and is realized when followed.
Its fragility is its strength; its simplicity is its direction - Michael Ham
"The E in Javascript stands for 'easy'." Florin Pop tweet
snownut2
« Reply #2 on: July 11, 2019, 11:05:10 AM »
V19 - 64bit
If I print through a pdf printer all is good, but when i try to Export to PDF its junk.
Any chance you could send me a screen shot of how you have export settings set.
MickD
« Reply #3 on: July 11, 2019, 06:31:35 PM »
I normally use pdf-creator to print to pdf but after trying it out yesterday I may change, it's very fast!
I don't know how to not print model space though...
my settings
Peter2
« Reply #4 on: July 12, 2019, 07:50:15 AM »
... but when i try to Export to PDF its junk....
can you upload an example?
Peter
AutoCAD Map 3D 2018 German (so some technical terms will be badly retranslated to English)
BricsCAD V21
snownut2
« Reply #5 on: July 12, 2019, 07:37:08 PM »
Sure, here's one, this won't open correctly in Adobe, but opens fine in Foxit.
Peter2
« Reply #6 on: July 14, 2019, 05:41:56 AM »
.... but opens fine in Foxit.
And in PDF XChange Viewer and Editor too ..
Peter
BricsCAD V21
