Author Topic: 2018 Civil 3D labels disappearing  (Read 18315 times)
estanima
« on: September 06, 2018, 12:44:57 PM »
Hello everyone,
Some of our users Civil 3D labels are disappearing. When they save their drawing they get an error, then when they open it all of their labels are gone.
Anyone run into this?
Re: 2018 Civil 3D labels disappearing
« Reply #1 on: September 06, 2018, 02:26:29 PM »
I have had many strange things happen in C3D. Usually if I run the recover command on the .dwg it will fix the problem.
« Reply #2 on: September 06, 2018, 02:54:01 PM »
Hello everyone,
What is the error message?
If it is something like, "some objects can not be saved in the current format"
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-One-or-more-objects-in-this-drawing-cannot-be-saved-to-the-specified-format.html
estanima
« Reply #3 on: September 06, 2018, 04:26:36 PM »
Thank you gentleman.  Recover didn't help.  Restoring backup files do.  Will try the other information as well.
Thank you very much :)
« Reply #4 on: September 06, 2018, 04:43:55 PM »
Posting a small sample file that exhibits the problem could help us, help you
rkmcswain
« Reply #5 on: September 07, 2018, 09:05:32 AM »
So just saving the drawing makes the labels vanish? In other words, you don't have to save, close, then reopen?
What label types specifically? Are these labels labeling items in an xref, or are they labeling local items in the DWG?
MSTG007
« Reply #6 on: September 07, 2018, 09:08:14 AM »
Weird. I had a instance yesterday, where I could not select any structures with my cursor but only pipes. I saved, audited, recovered, -pu regapps. Nothing worked. Then I got smart kinda. I just inserted that drawing into a blank drawing. Everything is back to normal. So I get the weird.
Civil3D 2020
estanima
« Reply #7 on: September 13, 2018, 01:13:37 PM »
Users go to save their drawings. When they save they get an error message. Then when they open the drawing ALL labels are gone.  About 20% of our people seem to be experiencing this.
« Reply #8 on: September 13, 2018, 01:22:45 PM »
What is the "ERROR" message?
rkmcswain
« Reply #9 on: September 18, 2018, 09:15:46 AM »
My guess is this one:
« Reply #10 on: September 18, 2018, 12:31:58 PM »
Yeah, I don't think I've had any labels go *poof* after that one....
Now the 'one or more objects can't saved in current format' one....that one will eat all sorts of things
estanima
« Reply #11 on: September 24, 2018, 06:59:48 PM »
MSTG007
« Reply #12 on: September 25, 2018, 07:38:27 AM »
The only time I usually get that error is when I File \ Export \ AutoCAD 2010. It will do it at the start of the command and then a second when its complete. Weird...
Civil3D 2020
rkmcswain
« Reply #13 on: September 25, 2018, 08:54:41 AM »
I see users getting this dialog all the time, on different versions of Civil 3D.
It's usually (seemingly) benign as no ill effects are seen, but it's annoying and scares a lot of users.
The KB article on it is totally bogus. It's not always a corrupt drawing.
estanima
« Reply #14 on: September 25, 2018, 08:16:20 PM »
Wish it was just scary rather than deleting every single label in our drawings :/
