Author Topic: Trouble with TraceBoundary After PromptStatus.Cancel  (Read 2363 times)
huaxiamengqing
« on: July 23, 2018, 10:51:49 AM »
Hi, Dear all.
 I have a trouble with traceboundary function.
I use code to let user input points  to get the boundaries by traceboundary function. But I allways get nothing by this function after user input  ESC when get points. The cad says that "No objects can be found on the screen"
  See code below
Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database = acDoc.Database
        Dim ed As Editor = acDoc.Editor
        Dim cucs As Matrix3d = ed.CurrentUserCoordinateSystem
        ed.CurrentUserCoordinateSystem = Matrix3d.Identity
        Dim rtpts As New List(Of Point3d)
        Try
            Do
                ' System.Windows.Forms.Application.DoEvents()
                Dim Mpso As New PromptPointOptions(vbCr & "Insert Points")
                'Dim Mpso As New PromptPointOptions(vbCr & "编号插入点")
                Dim psr As PromptPointResult = ed.GetPoint(Mpso)
                Dim selectpt As Point3d = Point3d.Origin
                If psr.Status = PromptStatus.OK Then
                    selectpt = psr.Value
                    rtpts.Add(selectpt)
                Else
                    Exit Do
                End If
                '' Start a transaction
                'Using dblock As Autodesk.AutoCAD.ApplicationServices.DocumentLock = acDoc.LockDocument
                '    Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                '        '' Open the Block table for read
                '        Dim acBlkTbl As BlockTable
                '        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
                '                     OpenMode.ForRead)
                '        '' Open the Block table record Model space for write
                '        Dim acBlkTblRec As BlockTableRecord
                '        acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace),
                '                        OpenMode.ForWrite)
                '        '' Create a single-line text object
                '        Stone.Layer.EnsureLayer("Stone_Points", 3)
                '        Using acPoint As DBPoint = New DBPoint()
                '            acPoint.Position = selectpt
                '            acPoint.Layer = "Stone_Points"
                '            acBlkTblRec.AppendEntity(acPoint)
                '            acTrans.AddNewlyCreatedDBObject(acPoint, True)
                '        End Using
                '        '' Save the changes and dispose of the transaction
                '        acTrans.Commit()
                '    End Using
                'End Using
            Loop
            Dim dbs As DBObjectCollection = ed.TraceBoundary(rtpts.First, True)
            MsgBox(dbs.Count.ToString)
        Catch ex As Exception
            ed.CurrentUserCoordinateSystem = cucs
        Finally
        End Try
You will always get  0 count dbs. But if I replace the TraceBoundary function into the  loop. It works well
see code below
dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Try
            Do
                    Dim dbs As DBObjectCollection = ed.TraceBoundary(selectpt, True)
                    rtpts.Add(selectpt)
                Else
                    Exit Do
                End If
                '                     OpenMode.ForRead)
                '        End Using
                '        acTrans.Commit()
                '    End Using
                'End Using
            Loop
        Finally
        End Try
That's really confused me. How anyone can give some suggestion.Thank you very much.
Jeff H
Re: Trouble with TraceBoundary After PromptStatus.Cancel
« Reply #1 on: July 23, 2018, 02:42:14 PM »
Just as a test edit your first example by pulling out of the loop
Code - Visual Basic: [Select]
  1. Dim selectpt As Point3d = Point3d.Origin
  2.
then change
  1. Dim dbs As DBObjectCollection = ed.TraceBoundary(rtpts.First, True)
  2.
to
  1. Dim dbs As DBObjectCollection = ed.TraceBoundary(selectpt, True)
  2.
huaxiamengqing
« Reply #2 on: July 23, 2018, 08:37:34 PM »
  2.
then change
  2.
to
  2.
Yes if you select one point not exit do by ESC, you will get the correct boundary.
But if you select more than one point and exit do by esc,psr.Status = PromptStatus.Cance, You will get nothing--!
That's really confused me these days
