Hi, Dear all.
I have a trouble with traceboundary function.
I use code to let user input points to get the boundaries by traceboundary function. But I allways get nothing by this function after user input ESC when get points. The cad says that "No objects can be found on the screen"
See code below
Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database = acDoc.Database
Dim ed As Editor = acDoc.Editor
Dim cucs As Matrix3d = ed.CurrentUserCoordinateSystem
ed.CurrentUserCoordinateSystem = Matrix3d.Identity
Dim rtpts As New List(Of Point3d)
Try
Do
' System.Windows.Forms.Application.DoEvents()
Dim Mpso As New PromptPointOptions(vbCr & "Insert Points")
'Dim Mpso As New PromptPointOptions(vbCr & "编号插入点")
Dim psr As PromptPointResult = ed.GetPoint(Mpso)
Dim selectpt As Point3d = Point3d.Origin
If psr.Status = PromptStatus.OK Then
selectpt = psr.Value
rtpts.Add(selectpt)
Else
Exit Do
End If
'' Start a transaction
'Using dblock As Autodesk.AutoCAD.ApplicationServices.DocumentLock = acDoc.LockDocument
' Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
' '' Open the Block table for read
' Dim acBlkTbl As BlockTable
' acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
' OpenMode.ForRead)
' '' Open the Block table record Model space for write
' Dim acBlkTblRec As BlockTableRecord
' acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace),
' OpenMode.ForWrite)
' '' Create a single-line text object
' Stone.Layer.EnsureLayer("Stone_Points", 3)
' Using acPoint As DBPoint = New DBPoint()
' acPoint.Position = selectpt
' acPoint.Layer = "Stone_Points"
' acBlkTblRec.AppendEntity(acPoint)
' acTrans.AddNewlyCreatedDBObject(acPoint, True)
' End Using
' '' Save the changes and dispose of the transaction
' acTrans.Commit()
' End Using
'End Using
Loop
Dim dbs As DBObjectCollection = ed.TraceBoundary(rtpts.First, True)
MsgBox(dbs.Count.ToString)
Catch ex As Exception
ed.CurrentUserCoordinateSystem = cucs
Finally
End Try
You will always get 0 count dbs. But if I replace the TraceBoundary function into the loop. It works well
see code below
dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Try
Do
Dim dbs As DBObjectCollection = ed.TraceBoundary(selectpt, True)
rtpts.Add(selectpt)
Else
Exit Do
End If
' OpenMode.ForRead)
' End Using
' acTrans.Commit()
' End Using
'End Using
Loop
Finally
End Try
That's really confused me. How anyone can give some suggestion.Thank you very much.
