Hi all,
I've decided to update my *.vlx files posted here :
https://www.theswamp.org/index.php?topic=53008.msg579668#msg579668What I've changed are some minor changes - some (vl-cmdf) calls are changed to (vla-xxx) calls in attempt to make it just a little faster, but main change was made to *-3proj.vlx files, where I still decided to keep original scaling of each projection (previously was 1.0 for top projection, 0.999 for front and 0.998 for left) in order to make as much as possible 3DSOLID transformation correct... But the issue I was faced and before I reattached files was that UNION command couldn't create single 3DSOLID entity from those 3 projections, so I have previously decided to change scaling of them like I stated above in ()... Still, I am not 100% sure if it's just my problem - I have just an ordinary PC, below today standards - I used it for at least over 10 years and haven't changed its configuration ever since... So my question : In some AutoCAD version on some OS with some better PC - more RAM and so on, are you able to union those 3 3DSOLIDS I've colored in red color in attached DWG? If you are able, then I'll leave those *-3proj.vlx unchanged, but I am very pessimistic about this as I believe that this is very old issue with AutoCAD - never really solved solid modelling operations ever since they were firstly introduced...
Thanks for testing and your opinion, M.R.
