Author Topic: xdata acad mep?  (Read 3442 times)
Amsterdammed
xdata acad mep?
« on: April 20, 2016, 08:55:24 AM »
Hello,
i try to figure same longshot out here. part of the solution could be xdata Manipulation in acad mep. Does anybody know here if there is a way to read xdata from acad mep objects created by ifc import out Revot mep? i need to do some automated work i cant get done in Revit, i thought i might be lucky in ACAD mep.
Thanks Bernd
Amsterdammed
Re: xdata acad mep?
« Reply #1 on: April 24, 2016, 08:08:25 AM »
Did i phrase did stupid or is there really nobody here who knows if there's a way to extract all the non graphical information from an acad mep object in vlisp???
all help or hints would be very much appreciated !!
Thanks Bernd
ChrisCarlson
Re: xdata acad mep?
« Reply #2 on: April 26, 2016, 10:35:21 AM »
I'm not sure what kind of information is stored but what is the result of this?
Re: xdata acad mep?
« Reply #3 on: April 26, 2016, 11:27:41 AM »
To see xdata you'll need to provide the applist portion of entget:
  1. (entget (car (entsel)) '("*"))
Amsterdammed
Re: xdata acad mep?
« Reply #4 on: April 26, 2016, 11:47:42 AM »
thought so too, i worked a lot with xdata, but its not "there". so i guess they acdaMEP works with xrecords or dictionaries?
ChrisCarlson
Re: xdata acad mep?
« Reply #5 on: April 26, 2016, 12:59:18 PM »
Command: xdlist
Initializing...
Select object:
Enter application name <*>:
No Xdata associated with Application Name(s).
Object has 16383 bytes of Xdata space available.
http://adndevblog.typepad.com/aec/2012/08/revit-dwgdxf-export-specification-of-the-extended-data-xdata.html
I don't have AutoCAD MEP but I recall seeing a screenshot showing a properties window in MEP showing the (for the lack of a better phrase) advanced properties.
//Edit
How did you export the IFC from Revit? Is it possible you exported it without attaching any additional information?
« Last Edit: April 26, 2016, 01:08:21 PM by ChrisCarlson »
Re: xdata acad mep?
« Reply #6 on: April 26, 2016, 01:46:01 PM »
Attached is the IFC I exported.
ChrisCarlson
Re: xdata acad mep?
« Reply #7 on: April 26, 2016, 01:59:06 PM »
That's annoying, Vanillia AutoCAD has ifcimport turned off.
Amsterdammed
Re: xdata acad mep?
« Reply #8 on: April 26, 2016, 02:07:50 PM »
@Chris,
the link you attached is revering to what is attached when you export an entity with the REVIt build in export function.
the solids have described xdata attached, i will study your link if i can ge tany wiser form the link. I
But John pointed me  (in the Revit forum on this site) to the IFC export option and then import that in ACAD mep. but those elements do not have xdata, but either xrecords or dictionaries, bot h not my favorites in other words, i don;t know enough about hem to extract all the info available. But in ACAD mep properties there is a tab called xdtata showing the properties i am interested in to create my shop drawings as i did in acad  but then fram a REVIT model.
Bernd
Amsterdammed
Re: xdata acad mep?
« Reply #9 on: April 26, 2016, 02:09:06 PM »
i attach again the elbow as dwg John created and i imported in MEP and saved as drawing.
roy_043
  • BricsCAD 18
Re: xdata acad mep?
« Reply #10 on: April 26, 2016, 02:35:30 PM »
The object (dwg from post #4) has an extension dictionary:
  1.   (vlax-vla-object->ename
  2.   )
  3.   "AEC_PROPERTY_SETS"
  4. )
  (-1 . <Entity name: cba2e28>)
  (0 . "DICTIONARY")
  (5 . "1F637")
  (102 . "{ACAD_REACTORS")
  (330 . <Entity name: cba2de8>)
  (102 . "}")
  (100 . "AcDbDictionary")
  (280 . 1)
  (281 . 1)
  (3 . "*A1")
  (360 . <Entity name: cba2e68>)
  (3 . "*A10")
  (360 . <Entity name: cba33e8>)
  (3 . "*A2")
  (360 . <Entity name: cba3468>)
  (3 . "*A3")
  (360 . <Entity name: cba2ee8>)
  (3 . "*A4")
  (360 . <Entity name: cba3028>)
  (3 . "*A5")
  (360 . <Entity name: cba30a8>)
  (3 . "*A6")
  (360 . <Entity name: cba3128>)
  (3 . "*A7")
  (360 . <Entity name: cba31a8>)
  (3 . "*A8")
  (360 . <Entity name: cba3228>)
  (3 . "*A9")
  (360 . <Entity name: cba32a8>)
The "*A1" etc. entries are (0 . "AecDbPropertySet") entities.
Amsterdammed
Re: xdata acad mep?
« Reply #11 on: April 27, 2016, 05:41:16 AM »
Roy,
I seem to be unable to retrieve information from that *A1 to *A10. if i try with entget i just get deeper into the (360. entity ) crap and don't seem to know what i am looking for.
 How does that work????
Bernd
roy_043
  • BricsCAD 18
Re: xdata acad mep?
« Reply #12 on: April 27, 2016, 07:52:58 AM »
I don't know what you should be looking for either, but the gc 360 entities contain the data. And I do see some form of data formatting (curly brackets):
  (102 . "{AEC_VARIANT")
  (70 . 72)
  (309 . "Standard")
  (102 . "AEC_VARIANT}")
  1.   (cdr
  2.     (assoc
  3.       -1
  4.       (dictsearch
  5.         (vlax-vla-object->ename
  6.           (vla-getextensiondictionary (vlax-ename->vla-object (car (entsel))))
  7.         )
  8.         "AEC_PROPERTY_SETS"
  9.       )
  10.     )
  11.   )
  12.   "*A1"
  13. )
  (-1 . <Entity name: cc1f438>)
  (5 . "1F638")
  (330 . <Entity name: cc1f3f8>)
  (102 . "}")
  (100 . "AecDbObject")
  (170 . 70)
  (102 . "{AEC_SUBOBJECT")
  (300 . "AecImpPropertySet")
  (100 . "AecImpObj")
  (170 . 70)
  (3 . "")
  (100 . "AecImpDictRecord")
  (170 . 70)
  (3 . "")
  (100 . "AecImpPropertySet")
  (170 . 70)
  (340 . <Entity name: cc1f378>)
  (341 . <Entity name: c989fb8>)
  (102 . "{AEC_PROPERTIES")
  (100 . "AecImpObj")
  (170 . 70)
  (3 . "")
  (100 . "AecImpArray")
  (170 . 70)
  (90 . 5)
  (300 . "AecProperty")
  (100 . "AecImpObj")
  (170 . 70)
  (3 . "")
  (100 . "AecProperty")
  (170 . 70)
  (92 . 0)
  (70 . 2)
  (71 . 0)
  (70 . 72)
  (309 . "Standard")
  (102 . "AEC_SUBOBJECT}")
  (100 . "AecImpObj")
  (170 . 70)
  (3 . "")
  (170 . 70)
  (92 . 6)
  (70 . 2)
  (71 . 0)
  (70 . 72)
  (309 . "Elbow - Generic:Standard:945841")
  (100 . "AecImpObj")
  (170 . 70)
  (3 . "")
  (170 . 70)
  (92 . 9)
  (70 . 2)
  (71 . 0)
  (70 . 72)
  (309 . "")
  (100 . "AecImpObj")
  (170 . 70)
  (3 . "")
  (170 . 70)
  (92 . 11)
  (70 . 2)
  (71 . 0)
  (70 . 72)
  (309 . "945841")
  (100 . "AecImpObj")
  (170 . 70)
  (3 . "")
  (170 . 70)
  (92 . 24)
  (70 . 2)
  (71 . 0)
  (70 . 72)
  (309 . "25$nBY7K515ua5eCwjNgIb")
  (102 . "AEC_PROPERTIES}")
  (102 . "{AEC_NULLOBJECT}")
  (100 . "AecDbDictRecord")
  (170 . 70)
  (100 . "AecDbPropertySet")
  (170 . 70)
« Last Edit: April 27, 2016, 08:01:21 AM by roy_043 »
roy_043
  • BricsCAD 18
Re: xdata acad mep?
« Reply #13 on: April 27, 2016, 08:05:22 AM »
Alternative way to get the entity list in my previous post:
  1.   (cdar
  2.     (cdr
  3.       (member
  4.         '(3 . "*A1")
  5.         (dictsearch
  6.           (vlax-vla-object->ename
  7.             (vla-getextensiondictionary (vlax-ename->vla-object (car (entsel))))
  8.           )
  9.           "AEC_PROPERTY_SETS"
  10.         )
  11.       )
  12.     )
  13.   )
  14. )
Amsterdammed
Re: xdata acad mep?
« Reply #14 on: April 27, 2016, 08:44:46 AM »
i don't get what you get out of this....
((-1 . <Entity name: 3a55dab500>) (0 . "AecDbPropertySet") (5 . "1F638") (102 . "{ACAD_REACTORS") (330 . <Entity name: 3a55dab4f0>) (102 . "}") (330 . <Entity name: 3a55dab4f0>))
is what i get in acad mep.
