Author Topic: Dual ModelSpace Viewport  (Read 3202 times)
MSTG007
« on: November 09, 2015, 10:00:30 AM »
Is there a variable that when you have 2 model space viewports (one plan view, and the other southwest view). The active cursor in the viewport will show normal while the other view port will dim / gray scale out? Then as you flip to the other view port, it does the same?
Civil3D 2020
Re: Dual ModelSpace Viewport
« Reply #1 on: November 09, 2015, 10:11:23 AM »
not that I am aware of....
MSTG007
« Reply #2 on: November 09, 2015, 10:17:30 AM »
Hey, Never know.
Civil3D 2020
ChrisCarlson
« Reply #3 on: November 09, 2015, 10:24:14 AM »
I'm confused, you can only be within one model space viewport at a time. You would never see the "greyed" out crosshair.
Plus, when you are in a SW Isometric view, the crosshair goes from an XY style to an XYZ.
MSTG007
« Reply #4 on: November 09, 2015, 10:30:29 AM »
Here is what I am running into. We use Civil3D so usually we have 2 viewports (modelspace) when designing and editing pipes. Currently we have the "preselectioneffect" on 1. Which helps us find where we are working in a plan view when we are active in the 3d view. I was seeing if it was possibly to dim/ fade the previous view so that the preselectioneffect would stand out even more.
Civil3D 2020
ChrisCarlson
« Reply #5 on: November 09, 2015, 11:17:17 AM »
Well PRESELECTIONEFFECT is 0 or 1. 1 highlights the selection of the previous window and 0 will simply show dashed lines representing the selection set. The way it sounds you want the display brightness (for the lack of a better term) reduced while keeping the selection highlighting the same?
« Reply #6 on: November 09, 2015, 11:29:17 AM »
Sounds like station tracking setto  ALL views would be a benefit to you in this instance:
_AeccStationTrackerAll
MSTG007
« Reply #7 on: November 09, 2015, 11:59:35 AM »
You know. I just tried that. It works if I am on a profile it will then tracker the alignment in plan view and then the pipe view in 3D View. But as just dragging my cursor just in plan view I get nothing... could be me though.
Civil3D 2020
« Reply #8 on: November 09, 2015, 12:06:52 PM »
hows does looking at those pipes in 3d view help you?
MSTG007
« Reply #9 on: November 09, 2015, 12:12:32 PM »
Well, I have been testing out using feature lines to grade my pipes then snap my pipes to the feature line vertex. I like it, its quick.
Civil3D 2020
« Reply #10 on: November 09, 2015, 12:22:18 PM »
uh huh, just that, that doesn't have to happen in a 3d view...
IF
feature lines and pipes (and target surface) are 'isolated' and one uses TAB key whilst selecting SNAP point to ensure feature line is the object being snapped to....
MSTG007
« Reply #11 on: November 09, 2015, 12:34:04 PM »
Hey speaking of a snap. With Pipes, is there away to make the snap (instead of the center of the pipe) to be the invert of the pipe?
Civil3D 2020
« Reply #12 on: November 09, 2015, 01:02:14 PM »
Beat the developers with floppy discs....
