Author Topic: Field - Date & Time  (Read 4424 times)
Fabricio28
Field - Date & Time
« on: November 06, 2015, 05:30:35 AM »
Hi all,
Why does field (date&time) isn't updated automatically in my project?
I have 13 layouts with field and I have to open each one and update manually.
Others fields just regen command works fine.
Re: Field - Date & Time
« Reply #1 on: November 06, 2015, 07:45:32 AM »
Just a couple ideas.
Note: The Date field is updated by UPDATEFIELD, but it is not updated automatically based on the setting of the FIELDEVAL system variable.
UPDATEFIELD (Command)
You can update a field manually when you want to see the latest value. The Date field never updates automatically and must be updated manually.
Fabricio28
« Reply #2 on: November 06, 2015, 08:31:09 AM »
Hi Mark
FIELDEVAL is 31.
« Reply #3 on: November 06, 2015, 08:45:48 AM »
FIELDEVAL is 31.
Fabricio28
« Reply #4 on: November 06, 2015, 08:53:17 AM »
FIELDEVAL is 31.
Thank you Mr Lee Mac and Mark  :-(
« Reply #5 on: November 06, 2015, 09:12:36 AM »
Is the field part of a block or xref? You can 'UPDATEFIELD' and select either. All the fields should update.
ChrisCarlson
« Reply #6 on: November 06, 2015, 09:21:25 AM »
Instead of date field use a diesel expression, it will be updated on regen.
Fabricio28
« Reply #7 on: November 06, 2015, 10:19:13 AM »
Hi
Chris,
It is a good idea. But I don't know how to use diesel expression.  :?
Fabricio28
« Reply #8 on: November 06, 2015, 10:20:25 AM »
13 layouts I mean paper space.
ChrisCarlson
« Reply #9 on: November 06, 2015, 10:27:10 AM »
Hi
Chris,
Try this
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS73099cc142f4875513fb5cd10c4aa30d6b-7afe.htm,topicNumber=d0e394867
In an rtext entity
  1. $(edtime, 0, MON DD"," YYYY - H:MMam/pm)
« Reply #10 on: November 06, 2015, 10:29:37 AM »
Field
Other
Diesel
sample>>>>
Fabricio28
« Reply #11 on: November 06, 2015, 10:50:08 AM »
Field
Other
Diesel
sample>>>>
Thank you guys,
How Can I put this format in diesel expression.
%<\AcVar CreateDate \f "%c">%
Regards
ChrisCarlson
« Reply #12 on: November 06, 2015, 10:54:32 AM »
Read the link....
  1. $(edtime, 0,M"/"D"/"YYYY - H:MM:SS AM/PM)
Fabricio28
« Reply #13 on: November 06, 2015, 10:57:44 AM »
Read the link....
Thank you Chris,
I forgot to insert *edtime.
Thank you
