Note: The Date field is updated by UPDATEFIELD, but it is not updated automatically based on the setting of the FIELDEVAL system variable.
UPDATEFIELD (Command)You can update a field manually when you want to see the latest value. The Date field never updates automatically and must be updated manually.
QuoteNote: The Date field is updated by UPDATEFIELD, but it is not updated automatically based on the setting of the FIELDEVAL system variable.FIELDEVAL is 31.
Quote from: FABRICIO28 on November 06, 2015, 08:31:09 AMQuoteNote: The Date field is updated by UPDATEFIELD, but it is not updated automatically based on the setting of the FIELDEVAL system variable.FIELDEVAL is 31.
I have 13 layouts with field and I have to open each one and update manually.
Instead of date field use a diesel expression, it will be updated on regen.
Quote from: FABRICIO28 on November 06, 2015, 05:30:35 AMI have 13 layouts with field and I have to open each one and update manually.Is the field part of a block or xref? You can 'UPDATEFIELD' and select either. All the fields should update.
Quote from: ChrisCarlson on November 06, 2015, 09:21:25 AMInstead of date field use a diesel expression, it will be updated on regen.HiChris,It is a good idea. But I don't know how to use diesel expression.
FieldOtherDiesel sample>>>>$(edtime, 0, MON DD"," YYYY - H:MMam/pm)
Read the link....Code - Auto/Visual Lisp: [Select]$(edtime, 0,M"/"D"/"YYYY - H:MM:SS AM/PM)
