Author Topic: automaticaly updated lenght in attributes  (Read 2547 times)
serge_c
« on: June 25, 2015, 03:30:20 AM »
Here is a big question : it's possible that lenght will updated automatically , not after saving the drawing
here is a dynamic block
phanks in advance !!!
kpblc
Re: automaticaly updated lenght in attributes
« Reply #1 on: June 25, 2015, 03:50:45 AM »
Change FIELDEVAL system variable to 31.
Sorry for my English.
serge_c
« Reply #2 on: June 25, 2015, 05:59:42 AM »
fieldval is 31 ,it's a initial value , I tried to modified this value with another , change it back to 31
the same thing it's does not work
kpblc
« Reply #3 on: June 25, 2015, 06:53:29 AM »
If FIELDEVAL equal to 31, you don't have to save dwg to check chanes: try to regen it. I tested your block with AutoCAD 2016 - values changes correctry (REGENMODE = 1).
serge_c
« Reply #4 on: June 25, 2015, 07:24:45 AM »
:) probably I don't explain corectly the final reason :
 After streching the rectangle the lenght it should automaticaly update , without regen or saving drawing , it should work like in this example :
kpblc
« Reply #5 on: June 25, 2015, 07:36:54 AM »
At this file you're using ProjectStudio. File has 69 proxyobjects and 24 regapps you can purge. Open this file at "clear" AutoCAD without any addons like PS, SPDS Graphics etc - and fields will be updated only at regen, save, plot etc (look at FIELDEVAL description).
Ketxu
« Reply #6 on: June 26, 2015, 09:22:47 AM »
I think it impossible now, and why don't you use a dimension object without Ext and Dim lines :)
CafeJr
« Reply #7 on: June 26, 2015, 11:28:41 AM »
Have you tryed use a dimension lines without "Extension lines" and "Symbols and Arrows"?
