Author Topic: Dinamic Block  (Read 10702 times)
Fabricio28
Dinamic Block
« on: February 25, 2015, 01:16:03 PM »
Hi guys!
How are you?
I'm trying to create a dinamic block, but the text isn't the center after rotate it.
Can you help me please?
Re: Dinamic Block
« Reply #1 on: February 25, 2015, 01:18:42 PM »
is your text CENTER Justified? is that Insertion point being used to define the center of the rotation parameter?
Fabricio28
Re: Dinamic Block
« Reply #2 on: February 25, 2015, 01:21:57 PM »
Yep my friend
text Center Justifield.
I think the problem is the rotate action.
I don't know how to fix it.
Re: Dinamic Block
« Reply #3 on: February 25, 2015, 01:25:11 PM »
no it's the stretch and move parameter they do not appear to include the text objects...
Fabricio28
Re: Dinamic Block
« Reply #4 on: February 25, 2015, 01:40:28 PM »
I've tried many times to include the text to move and stretch parameter. Isn't working.
Could you please, Attach a example for me, please?
Re: Dinamic Block
« Reply #5 on: February 25, 2015, 01:44:57 PM »
Here is a sample...
Note I used some geometric constraints to link a line
and a circle...the text is also constrained....
Then when stretched things stay centered....
Fabricio28
Re: Dinamic Block
« Reply #6 on: February 25, 2015, 01:56:43 PM »
Here is a sample...
I'm studying your block and I didn't get it.
I'm not used to create like that.
Re: Dinamic Block
« Reply #7 on: February 25, 2015, 01:58:22 PM »
Here is a sample...
Trust that is NOT the ONLY way, however it is how I might do it...
to ensure the ext stayed centered once the section line was stretched and or rotated....
Fabricio28
Re: Dinamic Block
« Reply #8 on: February 25, 2015, 02:03:48 PM »
Here is a sample...
I think the rotate action is wrong in my block, because isn't following the strech command.
Jeff H
Re: Dinamic Block
« Reply #9 on: February 25, 2015, 02:07:12 PM »
See attached
Just modify move action to include rotation parameter so its center or rotation point is moved with stretch action.
Fabricio28
Re: Dinamic Block
« Reply #10 on: February 25, 2015, 02:11:39 PM »
See attached
Just simple like that?
I tried and worked!!
Thank you very much Jeff
Thank you mjfarrell!
Re: Dinamic Block
« Reply #11 on: February 25, 2015, 03:17:33 PM »
you are welcome...
notice that you now have TWO ways to approach this function
if you study my block...and make one like it that works the same way...
blessing and the curse of autocad
most always more than one way to accomplish the same end state
