is your text CENTER Justified? is that Insertion point being used to define the center of the rotation parameter?
no it's the stretch and move parameter they do not appear to include the text objects...
Here is a sample...Note I used some geometric constraints to link a lineand a circle...the text is also constrained....Then when stretched things stay centered....
Quote from: mjfarrell on February 25, 2015, 01:44:57 PMHere is a sample...Note I used some geometric constraints to link a lineand a circle...the text is also constrained....Then when stretched things stay centered....I'm studying your block and I didn't get it.I'm not used to create like that.
Quote from: FABRICIO28 on February 25, 2015, 01:56:43 PMQuote from: mjfarrell on February 25, 2015, 01:44:57 PMHere is a sample...Note I used some geometric constraints to link a lineand a circle...the text is also constrained....Then when stretched things stay centered....I'm studying your block and I didn't get it.I'm not used to create like that.Trust that is NOT the ONLY way, however it is how I might do it...to ensure the ext stayed centered once the section line was stretched and or rotated....
See attachedJust modify move action to include rotation parameter so its center or rotation point is moved with stretch action.
