If I have the PEDITACCEPT system variable set to 1, it works as it should, but for some reason it messes up the MPEDIT command. When I select multiple Lines to convert to PLines, it still prompts me for a response and when I select YES, it says "Invalid option keyword" and it only converts 1 object and leaves the rest. Is this a known issue in AutoCAD 2014?
Kr. Robbo.
