I have two PCs with AutoCAD 2013 Mechanical. The installations are exactly similar and are fully updated.
In a drawing I insert a dynamic block and update its parameters using Properties dialog box. It is not very comples and contains 11 parameters.
On PC1, the parameters update almost instantaneously while on PC2 it takes alomost 2 seconds to update a parameter.
Can somebody help me with a solution? Thanks in Advance.
