Author Topic: Dynamic block updating slow  (Read 4616 times)
sskEmrsn
« on: September 05, 2014, 06:06:41 AM »
I have two PCs with AutoCAD 2013 Mechanical. The installations are exactly similar and are fully updated.
In a drawing I insert a dynamic block and update its parameters using Properties dialog box. It is not very comples and contains 11 parameters.
On PC1, the parameters update almost instantaneously while on PC2 it takes alomost 2 seconds to update a parameter.
Can somebody help me with a solution? Thanks in Advance.
Re: Dynamic block updating slow
« Reply #1 on: September 05, 2014, 09:16:04 AM »
perhaps PC2 is just slow?
toss them out a window at the same time
if PC 2 hits the ground last
it was just slow
Bethrine
« Reply #2 on: September 05, 2014, 10:22:17 AM »
it was just slow
Physics says they will hit the ground at the same time, doesn't it?  :?
I agree, it's probably the computer.
