bonjour, I'm trying to migrate from acad2012 to acad2015
I've got two drawings opened in acad2015, each one containing only 1 rectangle
When I select the rectangle in dwg A, then switch to dwg B via Ctrl+Tab, then switch back to dwg A via Ctrl+Tab, the rectangle is no longer selected
Is there a settings in acad2015 to prevent loosing the active selection ?
