Author Topic: autocad 2015 switching tabs loose active selection  (Read 4681 times)
ZNETQ
« on: August 06, 2014, 04:30:27 AM »
bonjour, I'm trying to migrate from acad2012 to acad2015
I've got two drawings opened in acad2015, each one containing only 1 rectangle
When I select the rectangle in dwg A, then switch to dwg B via Ctrl+Tab, then switch back to dwg A via Ctrl+Tab, the rectangle is no longer selected
Is there a settings in acad2015 to prevent loosing the active selection ?
Crank
Re: autocad 2015 switching tabs loose active selection
« Reply #1 on: August 06, 2014, 05:20:32 AM »
A major change in AutoCAD2015 is the complete removal of Microsoft's long-deprecated fiber technology.
That means mid-command document switching is no longer supported. Every time you'll try do this a *CANCEL* is send to the command.
More information:
https://www.youtube.com/watch?v=mEfdozjN62Y
Rob...
« Reply #2 on: August 06, 2014, 06:40:27 AM »
I thought I was looking forward to 2015. I guess there is always select previous.
CAD Tech
ZNETQ
« Reply #3 on: August 06, 2014, 07:38:34 AM »
Thanks for the link
I'm not switching in the middle of a command, there is no command, there is no Cancel
I just select the object by clicking on it and then switch tab
« Reply #4 on: August 06, 2014, 08:47:24 AM »
Thanks for the link
Why are you switching tabs?
Why not tile the windows and work between them in a tiled configuration?
ZNETQ
« Reply #5 on: August 06, 2014, 09:41:02 AM »
I don't think Tiling would fit our workflow as we open many drawings in the same session
« Reply #6 on: August 06, 2014, 10:08:07 AM »
This suggests you change that habit to gain greater efficiency.
