Author Topic: Help List  (Read 5968 times)
velasquez
Re: Help List
« Reply #15 on: July 30, 2014, 05:47:20 PM »
Quick one:
  1. (setq l
  2.    '(
  3.         ("3" "CC90B-BLUTOPPECB;Curva 90° com bolsas JE - Sistema Blutop;90;0;0;0")
  4.         ("2" "CP90FB-BLUTOP10/16PECB;Curva 90° com pé, bolsa e flange JE - Sistema Blutop;80;80;10;0")
  5.         ("1" "TBLUTOP;Tubo ponta e bolsa JE - Sistema Blutop;90;0;0;2000")
  6.         ("" "KB-BLUTOPPECB;Cap JE - Sistema Blutop;90;0;0;0")
  7.         ("" "KB-BLUTOPTIPECB;Cap JTI - Sistema Blutop;160;0;0;0")
  8.     )
  9. )
  10.
  11. (vl-sort l '(lambda ( a b ) (if (and (/= "" (car a)) (/= "" (car b))) (< (atoi (car a)) (atoi (car b))))))
I'm trying to sort a list by its second element.
The first element is always variable.
Laboring with the result vl-sort not working.
Lee Please can you tell me what is wrong?
(setq l '(
          ("-" "TNATJGS" "Tê com bolsas e junta elástica JGS - Linha Natural" "80" "80" "0" "0")
          ("-" "VBFWCV10" "Válvula borboleta com flanges e volante na posição 1" "200" "0" "10" "0")
          ("C" "VBFWCV10" "Válvula borboleta com flanges e volante na posição 1" "200" "0" "10" "0")
          ("-" "KB-BLUTOPTIPECB" "Cap JTI - Sistema Blutop" "160" "0" "0" "0")
          ("-" "CC90B-BLUTOPPECB" "Curva 90° com bolsas JE - Sistema Blutop" "90" "0" "0" "0")
          ("-" "TBLUTOP" "Tubo ponta e bolsa JE - Sistema Blutop" "90" "0" "0" "2000")
          ("5" "VBFWCV10" "Válvula borboleta com flanges e volante na posição 1" "200" "0" "10" "0")
          ("-" "CC22B-BLUTOPPECB" "Curva 22°30' com bolsas JE - Sistema Blutop" "90" "0" "0" "0")
         ) ;_ fim de list
(vl-sort l '(lambda (a b) (eq (cadr a) (cadr b))))
Re: Help List
« Reply #16 on: July 30, 2014, 06:35:29 PM »
Try this:
(vl-sort l '(lambda (a b) (< (cadr a) (cadr b))))
velasquez
Re: Help List
« Reply #17 on: July 30, 2014, 07:13:41 PM »
Try this:
Thanks ronjonp I used your suggestion in a function to count the items in a list.
Can you tell me how I can improve my way?
(defun JoyFinalizaLista (lst / n ent wrt)
  (while (> (length lst) 0)
    (setq ent (car lst)
          n   0
    ) ;_ fim de setq
    (while (and (car lst)
                (eq (cadr (car lst)) (cadr ent))
           ) ;_ fim de and
      (setq n (1+ n))
      (setq lst (cdr lst))
    ) ;_ fim de while
    (setq wrt (cons (append ent (list n)) wrt))
  ) ;_ fim de while
  wrt
;;;Result -> '(("-" "VBFWCV10" "Válvula borboleta com flanges e volante na posição 1" "200" "0" "10" "0" 3) ("-" "TNATJGS" "Tê com bolsas e junta elástica JGS - Linha Natural" "80" "80" "0" "0" 2) ("-" "TBLUTOP" "Tubo ponta e bolsa JE - Sistema Blutop" "90" "0" "0" "2000" 1) ("-" "KB-BLUTOPTIPECB" "Cap JTI - Sistema Blutop" "160" "0" "0" "0" 1) ("-" "CC90B-BLUTOPPECB" "Curva 90° com bolsas JE - Sistema Blutop" "90" "0" "0" "0" 1) ("-" "CC22B-BLUTOPPECB" "Curva 22°30' com bolsas JE - Sistema Blutop" "90" "0" "0" "0" 1))
Re: Help List
« Reply #18 on: July 30, 2014, 09:50:21 PM »
Did you try this as suggested by Ron?
(defun JoyFinalizaLista (l)
velasquez
Re: Help List
« Reply #19 on: July 31, 2014, 07:08:45 AM »
Hello CAB,
Ron's suggestion worked perfectly.
I failed my goal when I showed her.
My question is the way that I showed to count the elements in the list can be improved.
I corrected my code.
(setq l '(
         ) ;_ fim de list
(defun JoyFinalizaLista (lst / lst n ent wrt)
;;;BY RONJONP
(setq lst (vl-sort lst '(lambda (a b) (< (cadr a) (cadr b)))))
    (setq ent (car lst)
          n   0
    ) ;_ fim de setq
           ) ;_ fim de and
      (setq n (1+ n))
    ) ;_ fim de while
  ) ;_ fim de while
  wrt
;;;TEST
_$ (JoyFinalizaLista l)
_$
Re: Help List
« Reply #20 on: July 31, 2014, 08:44:28 AM »
I don't understand what you are counting?
velasquez
Re: Help List
« Reply #21 on: July 31, 2014, 01:10:58 PM »
I'm counting the second item of each list (cadr ..) and adding the value at the end of the list.
I used the idea of ​​Ron to sort the list.
Please exeucte my code and observe the returned list.
Re: Help List
« Reply #22 on: July 31, 2014, 02:05:49 PM »
Give this a try:
(setq
  l '(("-" "TNATJGS" "Tê com bolsas e junta elástica JGS - Linha Natural" "80" "80" "0" "0")
     ) ;_ fim de list
(mapcar
  (function
    (lambda (x)
      (append
x
(list (length (vl-remove-if-not (function (lambda (txt) (= (cadr x) txt))) (mapcar 'cadr l)))
  l
« Last Edit: July 31, 2014, 02:42:47 PM by ronjonp »
velasquez
Re: Help List
« Reply #23 on: July 31, 2014, 03:04:29 PM »
Give this a try:
(setq
     ) ;_ fim de list
(mapcar
  (function
    (lambda (x)
      (append
x
  l
Hi Ron,
Your code did the count I need.
But the list of return must be in the format below.
I'll study it.
Thank you very much.
(finalList '(("-" "VBFWCV10" "Válvula borboleta com flanges e volante na posição 1" "200" "0" "10" "0" 3) ("-" "TNATJGS" "Tê com bolsas e junta elástica JGS - Linha Natural" "80" "80" "0" "0" 2) ("-" "TBLUTOP" "Tubo ponta e bolsa JE - Sistema Blutop" "90" "0" "0" "2000" 1) ("-" "KB-BLUTOPTIPECB" "Cap JTI - Sistema Blutop" "160" "0" "0" "0" 1) ("-" "CC90B-BLUTOPPECB" "Curva 90° com bolsas JE - Sistema Blutop" "90" "0" "0" "0" 1) ("-" "CC22B-BLUTOPPECB" "Curva 22°30' com bolsas JE - Sistema Blutop" "90" "0" "0" "0" 1)))
Re: Help List
« Reply #24 on: July 31, 2014, 03:49:22 PM »
Give this a whirl:
(while (setq line (car l))
  (setq tmp (vl-remove-if-not (function (lambda (x) (= (cadr line) (cadr x)))) l))
  (setq result (cons (append line (list (length tmp))) result))
  (mapcar (function (lambda (x) (setq l (vl-remove x l)))) tmp)
(setq result (vl-sort result '(lambda (a b) (< (cadr a) (cadr b)))))
Re: Help List
« Reply #25 on: July 31, 2014, 04:51:07 PM »
Another variation:
  1. (defun foo ( l / a r )
  2.     (foreach x l
  3.         (if (setq a (assoc (cadr x) r))
  4.             (setq r (subst (subst (1+ (last a)) (last a) a) a r))
  5.             (setq r (cons  (append (cons (cadr x) x) '(1)) r))
  6.         )
  7.     )
  8.     (vl-sort (mapcar 'cdr r) '(lambda (a b) (> (cadr a) (cadr b))))
  9. )
Re: Help List
« Reply #26 on: July 31, 2014, 04:53:50 PM »
And another:
  1. (defun foo ( l / n r x )
  2.     (while l
  3.         (setq x (car l)
  4.               n (length l)
  5.               l (vl-remove-if '(lambda ( y ) (= (cadr x) (cadr y))) (cdr l))
  6.               r (cons (append x (list (- n (length l)))) r)
  7.         )
  8.     )
  9.     (vl-sort r '(lambda (a b) (> (cadr a) (cadr b))))
  10. )
velasquez
Re: Help List
« Reply #27 on: July 31, 2014, 05:25:35 PM »
Again your help was very important.
Thanks for the time you dedicated to my problems.
