Author Topic: passing vectors to a function  (Read 11207 times)
Shay Gaghe
« on: July 08, 2014, 11:48:39 AM »
Hi
i want to pass 2 vectors to test if they are perpendicular, i wanna use  Lee Mac function for this, cant figure out how.
  1. ;; Perpendicular-p  -  Lee Mac
  2. ;; Returns T if vectors v1,v2 are perpendicular
  3.
  4. (defun LM:Perpendicular-p ( v1 v2 )
  5.     (equal 0.0 (vxv v1 v2) 1e-8)
  6. )
  7.
  8. ;; Vector Dot Product  -  Lee Mac
  9. ;; Args: u,v - vectors in R^n
  10.
  11. (defun vxv ( u v )
  12.     (apply '+ (mapcar '* u v))
  13. )
  14.
Shay
Re: passing vectors to a function
« Reply #1 on: July 08, 2014, 12:00:23 PM »
The syntax of Lee Mac's code is (call or use his function like this):
  1. (LM:Perpendicular-p vector1 vector2)
Shay Gaghe
« Reply #2 on: July 08, 2014, 12:31:34 PM »
but what are those vectors? we always passing points...i never thought that vectors are something you can refer to in Autolisp.
can anyone post a simple example on how to use that particular function?
« Reply #3 on: July 08, 2014, 12:50:31 PM »
Yes, a vector can be expressed as a point.
A vector which originates at 0,0,0 has its direction and magnitude expressed by the point it 'points' to.
This has a section on vectors
https://www.khanacademy.org/math/precalculus
« Last Edit: July 08, 2014, 01:04:36 PM by Kerry »
« Reply #4 on: July 08, 2014, 01:15:51 PM »
As others have explained, a vector is simply a displacement by a given amount in a given direction, usually expressed relative to the origin; this is equivalent to the coordinates of a point given by that same displacement from the origin - e.g. the vector (5,3) defines a displacement of 5 units in the x-direction and 3 units in the y-direction, however, this same definition applies to the point (5,3) which is also 5 units in the x-direction & 3 units in the y-direction from the origin.
Here is an example, calling my function with two 2D vectors:
  1. (LM:perpendicular-p '(1 2) '(-2 1))
Shay Gaghe
« Reply #5 on: July 08, 2014, 02:59:02 PM »
ok, if i understand correctly (see attachment) , you gave the function only 2 points, (1,2) and (1,-2) ,
how come the function knows the origin?
WILL HATCH
« Reply #6 on: July 08, 2014, 03:56:15 PM »
Somebody needs a good lesson on vectors.  A point and a vector from the origin are the same thing for most intents and purposes (avoiding units etc.) as a vector is the difference between 2 points p1 and p2
Vector V1-2 from p1 to p2
i.e. V1-2 = p2 - p1
i.e vector = head point - tail point      where the arrow is at the head
In this case p1 = {0,0}  and V1-2 = p2
« Reply #7 on: July 08, 2014, 09:43:27 PM »
I take it that you haven't looked at the link I posted.
The parameters are NOT necessarily actual points. They are a list ( each with 2 or 3 elements)  representing the magnitude of the vector.
« Last Edit: July 08, 2014, 09:47:28 PM by Kerry »
hanhphuc
« Reply #8 on: July 08, 2014, 11:59:45 PM »
The idea of vector can be delta of 2 points,
Example: we should know 45⁰ degrees is 1:1,
;if 1st vector with 45⁰ :
;delta X= (cos (* pi 0.25)) , delta Y= (sin (* pi 0.25))
;ie: delta X= +0.707107 ; delta Y=+0.707107  <--- 1:1
;if 2nd vector with 135⁰ :
;delta X=(cos (* pi 0.75)) , delta Y= (sin (* pi 0.75))
;ie: delta X= -0.707107 ; delta Y=+0.707107  <---- -1:1
(VxV '(+0.707107 +0.707107 ) ; 45⁰
'( -0.707107 +0.707107 )); 135⁰
;matrix
(mapcar '*
'(-0.707107 +0.707107 )); 135⁰
= '(-0.5 0.5) ;
-0.5 + 0.5 = 0.0
; returns zerop, ie: per-p T
similar thread in cadtutor recently?
( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" ) ; error: too many arguments
irneb
« Reply #9 on: July 09, 2014, 01:56:15 AM »
To make it clearer, a point is the XYZ in a Cartesian coordinate system. A vector is the difference between 2 points, either expressed as the XYZ differences (coordinate vector) or the angle and distance (polar vector).
As an example, see attached. A line (vector) from point A to point B.
The Vx is the calculation of the coordinate vector (referred to as the Delta of a line segment), while the Vp is the calculation of the polar vector (the length and angle of a line segment).
irneb
« Reply #10 on: July 09, 2014, 02:07:08 AM »
You're kidding right? The "origin" is always 0,0,0 ... that's what "origin" in Cartesian coordinates mean, even when referring to a relative origin (which is what's going on here).
Think of it as a coordinate vector being made by moving both points at the same time such that the 1st point is at 0,0,0 then reading what the 2nd point's coordinates are. That IS a coordinate vector - i.e. how much difference between the XYZ values of the 2 points.
Shay Gaghe
« Reply #11 on: July 09, 2014, 11:56:24 AM »
of course i did watch the link you post,
i just missed the most important part which is that vectors are all about their origin,
it took me time to understand how 2 vectors can express 3 points,
now i got it
Thanks you
Shay
« Reply #12 on: July 09, 2014, 07:21:42 PM »
now i got it
Great to hear. It's an important concept in graphics and math.
Shay Gaghe
« Reply #13 on: July 10, 2014, 11:59:54 AM »
(-4x-4) + (4x4) = 0
but when i tried this on some other points the same math wont work, why?
« Reply #14 on: July 10, 2014, 12:14:26 PM »
It's not perpendicular
