Author Topic: passing vectors to a function  (Read 11209 times)
Shay Gaghe
Re: passing vectors to a function
« Reply #15 on: July 10, 2014, 12:46:02 PM »
It's not perpendicular
thanks
i update the shape , what math is to be applied here in order to get answer 0?
« Reply #16 on: July 10, 2014, 01:49:16 PM »
Firstly, note that you would need to supply the function with the vectors (-1.1 5.6) & (5.6 1.2), since you are looking for the vectors emanating from the point (8.4 -2.3):
  1. _$ (mapcar '- '(7.3 3.3) '(8.4 -2.3))
  2. (-1.1 5.6)
  3. _$ (mapcar '- '(14.0 -1.1) '(8.4 -2.3))
  4. (5.6 1.2)
However, these vectors are still not perpendicular (89.0183 degrees apart):
  1. _$ (rtd (acos (/ (vxv '(-1.1 5.6) '(5.6 1.2)) (|v| '(-1.1 5.6)) (|v| '(5.6 1.2)))))
  2. 89.0183
Shay Gaghe
« Reply #17 on: July 10, 2014, 02:19:35 PM »
  2. (-1.1 5.6)
  4. (5.6 1.2)
  2. 89.0183
Where I can find all those math functions like vxv , v etc?
LE3
« Reply #18 on: July 10, 2014, 02:26:55 PM »
You need to take a trip/visit to Lee's site:
http://www.lee-mac.com/index.html
And spend some time reading all the GREAT STUFF, he have in there for many to simple use OOB or to learn (<- I recommend)... AFAIK some of those function names are Lee's... HTH
« Reply #19 on: July 10, 2014, 02:28:01 PM »
I think I've already given you the link in your thread over at CADTutor, but if not: Mathematical Functions
« Reply #20 on: July 10, 2014, 02:28:28 PM »
Many thanks Luis - that's very kind of you  :-)
Shay Gaghe
« Reply #21 on: July 10, 2014, 02:38:44 PM »
Yes you did, I find it now under the scary  word "metrix" so no wonder how I've missed it.
Is there any mathematical explination about those functions?
« Reply #22 on: July 10, 2014, 02:43:44 PM »
Certainly, simply type the function names (e.g. 'Vector Dot Product' or 'Matrix Determinant') into Wikipedia.
Tharwat
  • Hypersensitive
« Reply #23 on: July 10, 2014, 05:07:39 PM »
Lee . Won't the following would be equivalent at anyway ?
  1. (defun Perpendicular-p (p1 org p2 / v)
  2.   ;;    Tharwat 11.July.2014    ;;
  3.   (or (equal (setq v (abs (- (angle p1 org) (angle p2 org))))
  4.              4.71239
  5.              1e-4
  6.       )
  7.       (equal v 1.5708 1e-4)
  8.   )
  9. )
  10.
« Reply #24 on: July 10, 2014, 05:17:40 PM »
Yes, however the use of the angle function will mean that 3D vectors will be dependent on the UCS.
Tharwat
  • Hypersensitive
« Reply #25 on: July 10, 2014, 06:01:26 PM »
Excellent - very precise :wink:
Shay Gaghe
« Reply #26 on: July 11, 2014, 01:06:51 AM »
hi
this code apply Lee's code on a selected entity ,
(defun entsel-pre-p (/ ent vertex vertexList u v vos)
  (if (setq ent (car (entsel "\nSelect an object")))
    (if (setq ent (entget ent))
(foreach vertex ent
  (if (= (car vertex) 10)
    (setq vertexList (cons (cdr vertex) vertexList))
(setq
  v (car vertexList)
  u (car (reverse vertexList))
(setq vos (apply '+ (mapcar '* u v)))
(equal 0.0 vos 1e-8)
if the selected poly origin is on 0,0,0 the function returns T , but if i move the poly and execute the code again it returns nil.
what i missing here?
Shay
« Reply #27 on: July 11, 2014, 01:10:18 AM »
Shay Gaghe,
If you're travelling in space and you are located at 10, 25,13 and you want to travel to Uranus which is at 12,21,15 ; what vector will Sulu need to
use to navigate to your destination?
(distances in parsecs).
« Reply #28 on: July 11, 2014, 01:17:42 AM »
Regarding the piccy you posted,
What is the vector for each of the arms in the left grid .. and in the right grid.?
ie:
What is it's Length, Delta X and Delta Y dimensions ?
« Last Edit: July 11, 2014, 01:23:30 AM by Kerry »
Shay Gaghe
« Reply #29 on: July 11, 2014, 01:27:36 AM »
ie:
i must know the location of Sulu
ie:
