Author Topic: lambda with strings  (Read 3293 times)
cadplayer
lambda with strings
« on: June 24, 2013, 07:21:38 AM »
Hello!
I need help with a string like this "Cut=\"172.87\"" to get two strings
 -"Cut"
 -"172.87"
My try is to read string after =
symbol (x) get "Cut"
symbol (y) get "172.87"
But it doesn´t work in anonym function, I have no expierence with lambda...
(setq str "Cut=\"172.87\"")
                                  (function
                                      (lambda (x y)
                                          (strcat
                                              (if (setq x (cdr (member 61 (reverse (vl-string->list x)))))
                                                  (setq x (vl-list->string (reverse x)))
                                              (if (setq y (cdr (member 61 (vl-string->list y))))
                                                  (vl-list->string (vl-remove-if-not '(lambda(X)(member X (vl-string->list "0123456789."))) y))
Tharwat
  • Hypersensitive
Re: lambda with strings
« Reply #1 on: June 24, 2013, 07:39:57 AM »
Maybe without lambda ...
  1. (setq str "Cut=\"172.87\"")
  2.
  3. (if (setq p (vl-string-search "=" str))
  4.   (setq cut (substr str 1 p))
  5. )
  6.
  7. (setq no (vl-list->string
  8.            (vl-remove-if-not
  9.              '(lambda (x)
  10.                 (member x '(46 48 49 50 51 52 53 54 55 56 57))
  11.               )
  12.              (vl-string->list str)
  13.            )
  14.          )
  15. )
  16.
cadplayer
« Reply #2 on: June 24, 2013, 07:58:42 AM »
Thanks it works fine and good suggestion, I build in as helper function... :angel:
Tharwat
  • Hypersensitive
« Reply #3 on: June 24, 2013, 08:01:14 AM »
You're welcome , and very happy to help .  :-D
BlackBox
« Reply #4 on: June 24, 2013, 09:37:53 AM »
FWIW - Here's a couple more ways of doing this, and a quick speed test... Each function tested returns a list of strings:
  1.
  2. (defun _foo1 (str / p)
  4.     (list
  5.       (substr str 1 p)
  6.       (vl-list->string
  7.         (vl-remove-if-not
  8.           '(lambda (x)
  9.              (member x '(46 48 49 50 51 52 53 54 55 56 57))
  10.            )
  11.           (vl-string->list str)
  12.         )
  13.       )
  14.     )
  15.   )
  16. )
  17.
  18. (defun _foo2 (str / p)
  19.   (if (setq p (vl-string-search "=" str))
  20.     (list
  21.       (substr str 1 p)
  22.         "\""
  23.         (vl-string-left-trim "\"" (substr str (+ 2 p)))
  24.       )
  25.     )
  26.   )
  27. )
  28.
  29. (defun _foo3 (str / p)
  30.   (if (setq p (vl-string-search "=" str))
  31.     (list
  32.       (substr str 1 p)
  33.       (rtos (atof (vl-string-translate "\"" "0" (substr str (+ 2 p))))
  34.             2
  35.             2
  36.       )
  37.     )
  38.   )
  39. )
  40.
... Results from console:
  1. _$ (bench '(_foo1 _foo2 _foo3) '("Cut=\"172.87\"") 10000)
  2.
  3. _FOO1
  4. Elapsed: 577
  5. Average: 0.0577
  6.
  7. _FOO2
  8. Elapsed: 78
  9. Average: 0.0078
  10.
  11. _FOO3
  12. Elapsed: 110
  13. Average: 0.0110
  14.
  15. _$
  16.
cadplayer
« Reply #5 on: June 24, 2013, 09:50:53 AM »
cool trials :-D
bench is it your own measure-tool?
BlackBox
« Reply #6 on: June 24, 2013, 09:56:46 AM »
cool trials :-D
No, it's actually R. Robert Bell's routine (AU Instructor, etc.), but he granted me permission to post it publicly here.
cadplayer
« Reply #7 on: June 24, 2013, 11:31:39 AM »
Thanx Blackbox: could be useful
BlackBox
« Reply #8 on: June 24, 2013, 11:44:26 AM »
You're welcome; I'm happy to help. :beer:
I do not find any value from this in production directly, but it is a useful utility for testing various ways of doing the same thing... There are many times, when I will not use the fastest, but instead use one close in speed, but easier to read, or provides a slightly different returned value based on usability with/without ObjectDBX, etc.... But one cannot make an informed decision without the applicable information.
Cheers
« Reply #9 on: June 30, 2013, 05:22:12 PM »
  1. (defun _foo2 (str / p)
  2.   (if (setq p (vl-string-search "=" str))
  3.     (list
  4.       (substr str 1 p)
  5.         "\""
  6.         (vl-string-left-trim "\"" (substr str (+ 2 p)))
  7.       )
  8.     )
  9.   )
  10. )
For what its worth, the left & right string trim could be replaced by a single vl-string-trim:
  1. (defun parse ( s / p )
  2.     (if (setq p (vl-string-position 61 s))
  3.         (list (substr s 1 p) (vl-string-trim "\"" (substr s (+ 2 p))))
  4.     )
  5. )
