Author Topic: BLOCK'S ATTRIBUTE  (Read 11746 times)
Fabricio28
BLOCK'S ATTRIBUTE
« on: November 01, 2012, 03:46:45 PM »
Hey all,
 I'm trying to create a dinamic block and add some attributes on it.
 But it didn't work. The Visibility States didn't work in my texts attribute. Why?
Does anybody Can help me, please??
Attached File.
Re: BLOCK'S ATTRIBUTE
« Reply #1 on: November 02, 2012, 02:19:48 AM »
from my experiments you need to add the attributes to the set of objects that should be visible, or invisible for each state
Fabricio28
« Reply #2 on: November 03, 2012, 07:47:05 AM »
the "didn't work" that he's talking about is that no matter what Visibility Options he chooses, all Attributes are showing (that is what i discover wheni tested his attached Dyna Block)
Anybody Can help me, please?
I'm using autocad 2012.
Thank in advance
« Reply #3 on: November 03, 2012, 10:06:55 AM »
whom are you quoting?
« Last Edit: November 03, 2012, 10:17:13 AM by mjfarrell »
Fabricio28
« Reply #4 on: November 03, 2012, 10:47:55 AM »
From a friend in augi forum. He's trying to help me.
Have seen my attached file??
I saw yours, and I know how I create this block like yours.
but I need to know if I am doing something wrong in my dinamic block.
Thanks in advance
« Reply #5 on: November 03, 2012, 11:02:57 AM »
A block like mine??  That one IS dynamic and the attribute supports the visibility state(s)
Did you insert the block? Or open the DWG file? As a DWG you will not experience the dynamic properties.
I don't think you are doing anything 'wrong'; however your order of operation is.
Yes I have seen your file;yes it has a problem.
I have found it best to ALways create all visibility states and LEAVE all objects alone when creating them
THEN
add the objects to the state(s)
« Last Edit: November 03, 2012, 11:06:00 AM by mjfarrell »
Fabricio28
« Reply #6 on: November 03, 2012, 11:10:06 AM »
THEN
It was exactly that I did.
I'll try to do it again on Monday.
Regards
Fabricio28
« Reply #7 on: November 06, 2012, 03:09:09 PM »
Hi all,
 I'm trying to create a visibility state to take off the "X" in the center of my dinamic block.
 I've tryed it all day long, without sucess.
Could somebody help me, please??
Regards
« Reply #8 on: November 06, 2012, 10:38:35 PM »
it appears to be the same order of operation situation as before
Fabricio28
« Reply #9 on: November 07, 2012, 05:39:36 AM »
Hi mjfarrell,
No, it isn't the same order of operation.
I want to create a parameter that that hide the "x", but separate from the visibililty parameter.
I don't know if I was clear.
Sorry for my english.
« Last Edit: November 07, 2012, 05:43:00 AM by FABRICIO28 »
« Reply #10 on: November 07, 2012, 09:24:09 AM »
Hi mjfarrell,
if you do not want that x just erase it...
or place on a layer that is off or frozen
or place a wipe-out over it
sadly your explanation of what you want doesn't help
post pictures...
otherwise I'm left with no solution, if it is about your visibility states not working for the object
then the solution is the same as before
Fabricio28
« Reply #11 on: November 07, 2012, 10:45:18 AM »
I need create other block like that, but without "x" in the center of the circle.
I'll need both blocks but one of them without "x".
Instead of create other block  without "x", just wanted to include other action that hide the "x".
« Reply #12 on: November 07, 2012, 10:50:09 AM »
then you will need to double up all visibility states...one without X, one with the X for every vis state
or block that includes the X in all vis states
and one without the X
Fabricio28
« Reply #13 on: November 07, 2012, 12:25:10 PM »
So, I'll will create other block without X. It's easier.
Thanks for take our time to help me out.
Regards
Jeff H
« Reply #14 on: November 07, 2012, 12:40:10 PM »
I am taking a guess but i think the problem is your adding a visibility state to a AttributeDefinition and when the block is inserted a AttributeReference is created and visibilty state is not applied, creating the 'x' using Mtext or Dtext would work or probably setting the attribute to constant so the blockreference will use the attributeDefinition might also work.
