Author Topic: IP address...  (Read 13918 times)
Patrick_35
Re: IP address...
« Reply #30 on: October 26, 2006, 05:26:19 PM »
Very nice
I suspected well that one could work with the activex, but I had not arrived yet there
Re: IP address...
« Reply #31 on: June 25, 2007, 12:36:46 PM »
Here ya go.
Written quickly. This means there are errors I failed to find | fix. Please follow prudent backup / testing methodologies. No warranty for any particular use is stated or implied. Use at your own risk.
(defun FindItemInFile ( PredicateFunction filename / handle item )
    ;;  © 2005 Michael Puckett
            (eq 'str (type filename))
            (setq handle (open filename "r"))
        (vl-catch-all-apply
           '(lambda ( / stream )
                (while (setq stream (read-line handle))
                        (   (PredicateFunction stream)
                            (close handle)
                            (setq item stream)
                            (exit)
                (close handle)
    item
(defun HiddenShellInPgpFile ( / filepath filebackup handle )
    (or
        (FindItemInFile
            (lambda (stream)
                (wcmatch
                    (strcase (vl-string-trim " \t\n" stream))
                    "HIDDENSHELL`,`,4`,`*OS COMMAND:`,"
            (setq filepath (findfile "acad.pgp"))
            filepath
            (setq filebackup (vl-filename-mktemp filepath))
            (vl-file-copy filepath filebackup)
            (setq handle (open filepath "a"))
            (princ "\nHiddenShell,,4,*OS Command:,\n" handle)
            (null (close handle))
            (setvar "re-init" 16)
(defun HiddenShell ( statement / cmdecho )
            (HiddenShellInPgpFile)
            (setq cmdecho (getvar "cmdecho"))
            (setvar "cmdecho" 0)
            (command "HiddenShell" statement)
            (setvar "cmdecho" cmdecho)
            t
(defun GetIPAddress ( / tempfile ipAddressStream ipAddress )
            (HiddenShell
                (strcat "ipconfig.exe > "
                    (setq tempfile
                        (vl-filename-mktemp "ipconfig.txt")
            (setq ipAddressStream
                (FindItemInFile
                    (lambda (stream)
                        (wcmatch
                            (strcase stream)
                            "*IP ADDRESS*"
                    tempfile
        (setq ipAddress
            (vl-string-trim " "
                (vl-list->string
                    (cdr
                        (member 58
                            (vl-string->list ipAddressStream)
    (if tempfile (vl-file-delete tempfile)) ;; clean up our mess
    ipAddress
Cheers.
:D
MP,
I made a small addition to your function so it would return the IP address on a Vista computer  :-):
(defun GetIPAddress (/ tempfile ipAddressStream ipAddress)
      (HiddenShell
(setq tempfile
     (FindItemInFile
       (lambda (stream)
(or
   (wcmatch
     (strcase stream)
     "*IP ADDRESS*"
   (wcmatch
     (strcase stream)
     "*IPV4 ADDRESS*"
       tempfile
     (setq ipAddress
    (vl-string-trim
      (vl-list->string
(cdr
  (member 58
  (if tempfile
  ipAddress
Re: IP address...
« Reply #32 on: February 27, 2009, 04:21:32 PM »
<Why all the interest (in particular guest views, sometimes 4 or more at a time) in this thread today?/weird>
Re: IP address...
« Reply #33 on: February 27, 2009, 05:17:17 PM »
I don't know...but after looking at my modification...I'd take out the OR (wcmatch (strcase stream) "*IP*ADDRESS*")  :-D
gskelly
Re: IP address...
« Reply #34 on: February 28, 2009, 05:50:01 PM »
I think it was referred to via a link in a message on WAUN... (not 100% I remember which list the message was from).
Bricscad v12
Re: IP address...
« Reply #35 on: March 01, 2009, 12:31:03 AM »
QFT
