Author Topic: Block Editor Rename?  (Read 11332 times)
craigr
« on: August 15, 2012, 10:58:00 AM »
I've recieved a drawing from a Coworker that has many blocks in it.
When I go to edit them in the Block Editor, they have nonsensicle names such as 'A$4E676C4A'.
I would like the names to actually mean something like '8inchbolt' instead. But, I don't want to have to explode each one and then make a new block with the new name.
Is there a command to just rename them?
craigr
Rob...
Re: Block Editor Rename?
« Reply #1 on: August 15, 2012, 11:04:19 AM »
There is a command "RENAME" but you don't get a preview of the block so you would have to know what they were from the name that they have now.
CAD Tech
craigr
« Reply #2 on: August 15, 2012, 11:05:20 AM »
Got it. - Thanks
I don't know how I haven't run into that before.
craigr
Rob...
« Reply #3 on: August 15, 2012, 11:06:16 AM »
In 2011 the block editor has is an option to "save as".
CAD Tech
dgorsman
« Reply #4 on: August 15, 2012, 11:27:22 AM »
Ah, yes, the joys of users discovering paste as block.  The users around here have been... educated... about not using that, precisely for that reason.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
HasanCAD
« Reply #5 on: August 16, 2012, 02:53:21 AM »
Rob...
« Reply #6 on: August 16, 2012, 05:42:10 AM »
CAD Tech
craigr
« Reply #7 on: August 16, 2012, 07:32:01 AM »
The 'Rename' thing worked great.
Though, as mentioned, it would be nice if there was a preview window so you don't have to remember the name of the block you want to change.
craigr
craigr
« Reply #8 on: August 21, 2012, 10:02:37 AM »
Another relate question....
Now that I have renamed their blocks to appropriate 'Standard' names, is there a way to change  the properties so that the block cannot be exploded?
Other than explode it and make a 'new block' with the same name and deselect the 'explode' option.
craigr
(edited) - Yes I DID look thru the properties box AND in the Block editor and haven't found the option. - It MAY be there, but I haven't been able to spot it.
(edit AGAIN) - I DID find it!!  - You have to open the Properties Bar within the Block editor. When I looked previously, I selected the block THEN opened the properties bar.
Craigr
« Last Edit: August 21, 2012, 10:08:42 AM by craigr »
Crank
« Reply #9 on: August 21, 2012, 03:21:23 PM »
Everybody could have told you that :P ;)
There is even an easier/faster way:
  • Start the BLOCK command (B , <ENTER>)
  • Select the block from the roll menu (ALT-N , <DOWNARROW>)
  • Check or uncheck 'Allow exploding' (ALT-E)
  • OK (<ENTER>)
  • Accept to redefine the block (<ENTER>)
Daniel J. Ellis
« Reply #10 on: August 22, 2012, 03:45:37 AM »
Good way to take advantage of an annoying feature there, Crank :)
dJE
dJE
Dommy2Hotty
« Reply #11 on: August 23, 2012, 02:07:24 PM »
I use this:
(defun c:BlockRename ()
  (setq bname (vla-get-EffectiveName (vlax-ename->vla-object (car(entsel "\nSelect block: ")))))
  (command "rename" "block" bname pause)
  );DEFUN
Command: blockrename
Select block:
rename
Enter object type to rename
[Block/Dimstyle/LAyer/LType/Material/Style/Tablestyle/Ucs/VIew/VPort]: block
Enter old block name: A$C7EDB4DDE
Enter new block name: New Block Name
Command: nil
« Reply #12 on: August 23, 2012, 05:25:20 PM »
  );DEFUN
A minor upgrade for you Dommy on the house:
  1. (defun c:blockrename ( / *error* ent )
  2.     (setq *error* '(( m ) (princ)))
  3.     (while
  4.         (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect Block: ")))
  5.             (cond
  6.                 (   (= 7 (getvar 'errno))
  7.                     (princ "\nMissed, try again.")
  8.                 )
  9.                 (   (= 'ename (type ent))
  10.                     (if (/= "INSERT" (cdr (assoc 0 (entget ent))))
  11.                         (princ "\nSelected object is not a Block.")
  12.                     )
  13.                 )
  14.             )
  15.         )
  16.     )
  17.     (if ent (command "_.-rename" "_B" (vla-get-effectivename (vlax-ename->vla-object ent)) "\\"))
  18.     (princ)
  19. )
craigr
« Reply #13 on: August 24, 2012, 07:37:22 AM »
Sometimes I feel like 'the red-headed stepchild' with you FULL CAD people.
« Reply #14 on: August 24, 2012, 08:26:57 AM »
What other options are there ?
