Another relate question....
Now that I have renamed their blocks to appropriate 'Standard' names, is there a way to change the properties so that the block cannot be exploded?
Other than explode it and make a 'new block' with the same name and deselect the 'explode' option.
craigr
(edited) - Yes I DID look thru the properties box AND in the Block editor and haven't found the option. - It MAY be there, but I haven't been able to spot it.
(edit AGAIN) - I DID find it!! - You have to open the Properties Bar within the Block editor. When I looked previously, I selected the block THEN opened the properties bar.
Craigr
