Author Topic: CAD/BIM Technology Center: A/E/C CAD Standard  (Read 5307 times)
CADUser
« on: June 29, 2012, 06:04:40 PM »
Hello Members,
I would like to use a template file offered by the CAD/Bim Technology Center. They have provided a group of templates for Architecture, which includes templates for model type, and also an .stb file.
But when I start a new sheet using one .dwt files, the plot style table assignments only displays .ctb files.
Can you please advise as how I can use this template with .stb.
Thank you,
CADUser
danallen
Re: CAD/BIM Technology Center: A/E/C CAD Standard
« Reply #1 on: June 29, 2012, 08:49:13 PM »
Try command CONVERTPSTYLES
CADUser
« Reply #2 on: June 29, 2012, 10:03:00 PM »
Thank you for the reply. That worked.
Now, I have encountered another dilemna. CAD/BIM Technology Center provided some dimension styles within the architecture templates. But when I go to dimension on object, whose actual size is 10'-0", the dimensions shows 120'-0".
What are your thoughts?
Thank you.
« Reply #3 on: June 29, 2012, 10:47:45 PM »
There is a scale factor being applied>> on the primary units tab of the Dimstyle
be sure that the tick box for Apply to Layout Dimensions Only is checked. (or remove the scale factor)
