Author Topic: Error Message  (Read 3029 times)
Rob...
Error Message
« on: February 23, 2012, 01:50:22 PM »
This is more than likely a compatability issue with running AutoCAD 2002 on Win 7 64 bit but does anyone know what this means?
CAD Tech
Matt__W
  • I like my water diluted.
Re: Error Message
« Reply #1 on: February 23, 2012, 01:55:14 PM »
I think it means your screen shot skills need a little tweaking.   :wink:
Autodesk Expert Elite
Rob...
Re: Error Message
« Reply #2 on: February 23, 2012, 01:57:06 PM »
Sorry...
CAD Tech
alanjt
  • Standby for witty remark...
Re: Error Message
« Reply #3 on: February 23, 2012, 02:23:39 PM »
:-D
Dropbox
Re: Error Message
« Reply #4 on: February 23, 2012, 03:19:50 PM »
you have wrong printer driver
Rob...
Re: Error Message
« Reply #5 on: February 23, 2012, 03:41:15 PM »
I thought Heidi had something to do with printing but I've since noticed that the error comes up when I double click on a block for editting in place.
CAD Tech
Re: Error Message
« Reply #6 on: February 23, 2012, 03:45:46 PM »
try turning OFF Hardware acceleration for your graphics card
dgorsman
Re: Error Message
« Reply #7 on: February 23, 2012, 03:59:31 PM »
My vote.  "wopengl7" would appear to be related to the video display.  This particular driver may not be playing well with 64-bit Win 7, kinda like leaded gasoline in a modern car.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Re: Error Message
« Reply #8 on: February 24, 2012, 01:37:06 AM »
+1
Rob...
Re: Error Message
« Reply #9 on: February 24, 2012, 08:43:01 AM »
Nothing has recently been changed on my computer except for Windows updates. This message comes up when doing something that I do daily. Hardware acceleration has been off for a long time and should still be. I will check it though. I'm not sure how it was done but IT had to jump through some loops to get what is actually an overly customized version of ADT3.3 to run on the 64 bit machines. One of the other guys has seen the message before but has just dealt with the occasional annoyance because AutoCAD keeps running normally after the error.
I'm thinking that has more to do with trying to run such an old program on the way newer OS and hardware. Our CAD manager refuses to support this program anymore, even though a majority of the company is still using it. He also has failed at getting a newer version running for the company. This has been going on for years but they still keep him in that position. I can't put all the blame on him though. A lot of it has to do with the fact that ADT3.3 is so customized for the company that it is very easy to use and the jump to 2011 (or any of the versions between for that matter) will put a big dent in the number of people that can be productive with AutoCAD. As far as I'm concerned, this has to change and quickly. I've got an idea that I'm pretty sure I can implement 2011 for my team. With just a few days or less of some tedious work, it should work. I may have to do some hours on my own time but, if I can do it successfully, it should give me a leg up to getting the raise that is so long over due and maybe even get that ITwit out of that position.
Well that turned into a bit of a rant, didn't it? Thanks for listening.
CAD Tech
Kyle Reese
Re: Error Message
« Reply #10 on: February 27, 2012, 06:30:58 AM »
Is your graphics card OpenGL compatible?
What card is installed in your computer?
It's a testament to your persistence that you can keep that old dog running for this long.  Kudos.
Re: Error Message
« Reply #11 on: February 27, 2012, 08:17:18 AM »
Rob,
ADT3.3 or any version of Autocad of that vintage had to have the installer tweaked to run on 64 bit.
That being said, I'm pretty sure most if not all of your customization will migrate forward quite seamlessly.
Recently I assisted some folks running 2007, and the migration took about 15 minutes on the first machine.
Then after a little testing that was reduced to changing a few paths, and setting a Profile current on subsequent workstations.
Rob...
Re: Error Message
« Reply #12 on: February 27, 2012, 11:03:52 AM »
Cheers guys! The hardware accelleration had gotten turned back on. Don't know how, but error message is gone for now.
CAD Tech
Re: Error Message
« Reply #13 on: February 27, 2012, 03:06:56 PM »
Why did you not check this sooner???    ;-)
Rob...
Re: Error Message
« Reply #14 on: February 27, 2012, 03:50:48 PM »
1. I was busy Thursday.
2. I was not in the office Friday.
3. I didn't check until the error came up today.
CAD Tech
