Author Topic: If within if  (Read 7532 times)
Re: If within if
« Reply #45 on: January 09, 2012, 07:37:59 PM »
That's not what I'm asking it to do, the memshna is used the same but in diferent conditions.  Here are the questions that the command line asks and the answers I put.
So you see the line of code is just the answers to the above question, and I don't need 'p'
The variable p in shapename is p2, just a LOCAL form of it.
caddman6425
Re: If within if
« Reply #46 on: January 09, 2012, 07:56:07 PM »
But you don't need it, why define that point twice, just use p2, it's only used in that one spot
Re: If within if
« Reply #47 on: January 09, 2012, 11:13:42 PM »
Because it's proper form to keep variables LOCALized.
It works both ways. SO do as you see fit.  8-)
caddman6425
Re: If within if
« Reply #48 on: January 10, 2012, 12:50:05 AM »
I'm sorry, I just don't understand.  Again, I'm sorry.
caddman6425
Re: If within if
« Reply #50 on: January 10, 2012, 11:50:57 AM »
Thank You,I will study
