Author Topic: If within if  (Read 6953 times)
caddman6425
Re: If within if
« Reply #30 on: January 09, 2012, 12:23:44 PM »
That's my problem, it isn't acting logically. But I can't get it to step, but I think it is at the point when you decide that you want a multi unit and pic tha tyou want (2), it seems as if I have a syntax problem here and it just skips it and goes to the end and operates the single part of the routine.  I don't know any way to say it better that this.
Re: If within if
« Reply #31 on: January 09, 2012, 12:36:27 PM »
Nick did you try the code I posted?
Do you get an error message?
caddman6425
Re: If within if
« Reply #32 on: January 09, 2012, 12:44:20 PM »
Not yet, I'm just now getting into the office and I wanted to post that answer, I'll get onto that code and try and see what I did wrong,  I do know what I hadn't finished yet though
caddman6425
Re: If within if
« Reply #33 on: January 09, 2012, 01:51:51 PM »
Boy I sure wish they had a smilie face scratching his head! :)
OK, CAB, why did you put these, (initget (+ 1 2 4)), here?  Oh oh, I just remembered why!  You don't know how good it feels to access a part of my memory that once was lost by those strokes.  Oh, this is so cool, praise GOD!!!!
Thank You CAB, this is now getting fun.
caddman6425
Re: If within if
« Reply #34 on: January 09, 2012, 02:15:22 PM »
OK, I bite, why the p2 after the shapename function?
Re: If within if
« Reply #35 on: January 09, 2012, 02:39:41 PM »
Rather than making p2 a global variable I sent it as an argument to the sub-function.
The p in the function keeps it local to that function.
caddman6425
Re: If within if
« Reply #36 on: January 09, 2012, 02:49:49 PM »
Uh, you do know that p2 is already called as a point, don't you?  Also, when you call the p before the "_Medium, _High, and the "" "" "",  it seems to me that it is going to bomb the command string.  Those are a specific set of answers to question that will define a structural member shape and style.  Or am I missing something?
Re: If within if
« Reply #37 on: January 09, 2012, 03:27:02 PM »
I am using ACAD 2006 so I can not test the routine but it appears to me that my modifications should work as intended.
The variable p2 is assigned a value at line 105 and never changed again. The sub function calls are later in the routine
and therefore use the same p2 as you intended. Only difference is that I have made it an argument in the sub function call.
caddman6425
Re: If within if
« Reply #38 on: January 09, 2012, 03:41:31 PM »
Just tried it on the command line and using the 'p' before the _Medium and so forth doesn't work.  As far as the p2 is concerned, it is only used for a point to define the position of the baseline in the profile that is defined and then that profile is deleted after the shape is defined.  What am I missing here, it seem that you are defining that point and defining it again as just p
Re: If within if
« Reply #39 on: January 09, 2012, 03:48:39 PM »
I'm a little confused.
Does the routine I posted work?
Do you call the sub-function shapename from the command line for any reason?
caddman6425
Re: If within if
« Reply #40 on: January 09, 2012, 03:55:51 PM »
On the command line you type out what is in that function, but it can be used 4 different times.  I'm lost, where do you call out 'p' as equal to 'p2'?
Re: If within if
« Reply #41 on: January 09, 2012, 04:03:38 PM »
(setq p2 '(10 25))
(shapename p2) ; sends the value (10 25) to the sub function shapename
(defun shapename (p)  ; this assigns (10 25) to the variable p
when shapename returns to the calling rutine the variable p is destroyed.
I have to go off for several hours..
caddman6425
Re: If within if
« Reply #42 on: January 09, 2012, 04:34:52 PM »
That's not what I'm asking it to do, the memshna is used the same but in diferent conditions.  Here are the questions that the command line asks and the answers I put.
Command: _-AECSMEMBERSHAPEDEFINE
Shape [New/Copy/Edit/Purge/?]: n
New style name or [?]: 2x12
New style 2x12 created.
Shape definition [Name/Description/Graphics]: G
Shape designation [Low detail/Medium detail/High detail]: L
Select lines, arcs, circles, or polylines for Low Detail: Here I put (entlast) and it returns: 1 found
Select lines, arcs, circles, or polylines for Low Detail: <enter out of command>
Insertion point or [Add entity]:Here is put the defined point 'p2'
Shape designation [Low detail/Medium detail/High detail]: M
Select a closed polyline, spline, ellipse, or circle for an outer ring:Here I put (entlast)
Insertion point or [Add ring/Centroid]:Here is put the defined point 'p2'
Shape designation [Low detail/Medium detail/High detail]: H
Shape designation [Low detail/Medium detail/High detail]: <enter out of command>
Shape definition [Name/Description/Graphics]: <enter out of command>
Shape [New/Copy/Edit/Purge/?]: <enter out of command>
So you see the line of code is just the answers to the above question, and I don't need 'p'
BlackBox
Re: If within if
« Reply #43 on: January 09, 2012, 05:37:55 PM »
You, who shall not be named, may want to reconsider posting your phone number publically in your signature. Just saying.
caddman6425
Re: If within if
« Reply #44 on: January 09, 2012, 05:55:08 PM »
Oooouh, you think?????
