CAB, you haven't posted some news, so all I could do is modify your version of v1.5... Everything is the same as my version, only it has now your dialog for linetypes and I think it's better now... So I named it v1.6 - changed title of main dialog (v1.6)... Still I couldn't fix the problem with v1.4 :
(initdia)
(command "_.LINETYPE")
and I've tried everything I could think of. By my current knowledge, I think I can't fix that bug. (only have tests on A2008 - but doesn't matter, it won't work and it won't and it won't...)
So, I am posting now v1.6. If you think I was wrong, you can remove line : (vl-file-delete dclname) - I use routine with deleting *.dcl after lsp ends (It isn't slower if needed to create new dcl, by my opinion, and I really don't want to create files on HD that are unnecessary - lisp will create it weather it exist or not. I only wanted to be removed after execution)... Anyway *.lsp is bigger, so why make the same data twice - dcl from lsp?
I've removed "load" option in your dialog - it loads all linetypes automatically from acadiso.lin (also if needed and user has it - user may change it to some other *.lin to be loaded automatically)... I don't know what you meant by "load" - "under construction
" - you haven't posted v1.6, so now it may be perhaps v1.7...
Thanks for thanking me, I only did what I could and had free time...
Regards, sincerely, M.R.
