Author Topic: Can someone steer a noob in the right direction?  (Read 12799 times)
NoTebowNoHope
Re: Can someone steer a noob in the right direction?
« Reply #15 on: January 09, 2012, 08:49:16 AM »
Info post - codes *.lsp files updated... Removed inspected lacks...
M.R.
 8-)
That is awesome! Thank you so much for putting this together! I feel like I owe something for your efforts. Is there a way to make a donation to the forums?
How difficult would it be to have a separate list each different group in step 1.?
ie...If I pick (S)ite, have options for 1,2,3,4,5
or if I pick (D)rainage have options for A,B,C,D
I really appreciate your time an effort you put into this!!!
« Reply #16 on: January 09, 2012, 09:59:21 AM »
M.R.
 8-)
... Is there a way to make a donation to the forums?
http://www.theswamp.org/donate.html  :-D
NoTebowNoHope
« Reply #17 on: January 09, 2012, 01:08:50 PM »
M.R.
 8-)
Thanks RonJon!
« Reply #18 on: January 10, 2012, 01:48:11 PM »
I'm a little behind here but see attached incomplete routine.
To finish:
Linetype selection
File reader - don't know what you wanted from a text file
« Last Edit: January 10, 2012, 03:42:08 PM by CAB »
« Reply #19 on: January 10, 2012, 03:42:50 PM »
Version 1.1 uploaded, Fixed a bug in the color dialog selection.
NoTebowNoHope
« Reply #20 on: January 10, 2012, 03:54:43 PM »
To finish:
Linetype selection
Regarding the file reader, it doesn't have to read a text file as I can edit the routine to suit for our specific plans.
Is it possible to have the scroll box in Step2 display a separate list for each category listed in Step1?
ie...
STEP1:      STEP2:
(S)ITE          (MASTER, DETAILED, LANDSCAPE)
(U)TILITY     (WATER, SEWER, REUSE)
(D)RAINAGE (DEMO, PREDEV, DETAILED, EROSION)
(R)OADWAY  (PROFILES, SECTIONS, DETAILS)
Thank you for your time and effort in setting this up. I really appreciate it and will make a donation to the site.
« Reply #21 on: January 10, 2012, 06:51:26 PM »
Yes, I'll get to adding the separate list tomorrow.
« Reply #22 on: January 10, 2012, 07:48:21 PM »
OK try this version.
Make sure you use the new DCL file.
NoTebowNoHope
« Reply #23 on: January 10, 2012, 09:39:41 PM »
I don't have cadd here at home but will try it first thing in the morning. Thanks again for your help!
« Reply #24 on: January 10, 2012, 10:46:07 PM »
You're welcome and thanks in advance for your contribution.
NoTebowNoHope
« Reply #25 on: January 11, 2012, 08:20:43 AM »
I tried it out this morning and it worked nicely!
How difficult would it be to incorporate the following:
1. Linetype dialog box similar to the color dialog?
2. Exit the dialog box when you hit "Create LAyer Now"
3. Set the newly created layer as current
I have no idea how much effort this took. Can you tell me about how much time you had in it so that I can make an appropriate donation to the site?
« Reply #26 on: January 11, 2012, 10:34:06 AM »
I'll have about 8 hours in the routine.
1. Linetype dialog box similar to the color dialog? I'll look into this
Done 2. Exit the dialog box when you hit "Create LAyer Now"
Done 3. Set the newly created layer as current
Version 1.3 when I get the line type option.
NoTebowNoHope
« Reply #27 on: January 12, 2012, 08:58:39 AM »
Thanks for the response...I really appreciate your help!
« Reply #28 on: January 12, 2012, 10:56:31 AM »
Could not find a quick fix for line type selection except for a simple list box with names only.
But I did find a routine included with ACAD 14 that has one with some display of simple line types.
I should have something by tomorrow. Other work is a priority today.
« Reply #29 on: January 12, 2012, 11:00:52 AM »
IIRC DOSLib includes a Linetype Selection box
