Author Topic: Arx documentation and VS 2010 Express Edition  (Read 2319 times)
autocart
« on: August 10, 2011, 01:52:38 AM »
I know this should be covered somewhere already but I could not find it on the web.
Is it possible to install the arx documentation in VS 2010 Express Edition, so that after pressing F1 on a highlighted class member in VS EE I get the corresponding help page displayed?
I have VS 2010 C# EE installed and did run the msi-installer of the arx doc but can't see any difference of behaviour inside VS EE.
Thx for any help,
Stephan
huiz
  • Certified Prof C3D
Re: Arx documentation and VS 2010 Express Edition
« Reply #1 on: August 10, 2011, 04:27:35 AM »
I did an install and I have help available in the Express version. But I can't remember which install I did. I think it is available from the AutoCAD website.
But I rather use website and pdf docs to find information, which is mostly more effective.
BlackBox
« Reply #2 on: August 10, 2011, 07:02:31 AM »
1+ Same here.
Also, did you figure out how to get Visual Studio 2010 Express (VSE) to properly Debug & hit Breakpoints, etc.? If not, I'd be happy to share.
kaefer
« Reply #3 on: August 10, 2011, 08:12:33 AM »
Sir, may I humbly suggest you did that with VS 2008 instead? See http://www.theswamp.org/index.php?topic=23356.0
huiz
« Reply #4 on: August 10, 2011, 08:42:45 AM »
I've checked but I really have 2012 ObjectARX reference guide in VB 2010 Express available. But I hardly use it.
huiz
« Reply #5 on: August 10, 2011, 08:45:33 AM »
1+ Same here.
Yes, editing the *.vbproj.user file manually, and off course, telling AutoCAD to use the right .NET framework.
BlackBox
« Reply #6 on: August 10, 2011, 12:32:36 PM »
1+ Same here.
Just to clarify, one needs to modify the applicable *.vbproj (VB.NET), or *.csproj (C#.NET) file and not the *.*proj.user file.
Also, depending on what versions you're developing code for, modifying acad.exe.config may also be necessary, despite setting your project to compile using the correct .NET framework.  :wink:
autocart
« Reply #7 on: August 11, 2011, 05:23:54 AM »
Thx to all,
I try the 2008 EE now. For Acad 2011 maybe better.
EDIT: It works now. Thx to all for help.
« Last Edit: August 11, 2011, 06:09:04 AM by autocart »
