Author Topic: AutoLisp this working?  (Read 3757 times)
velasquez
« on: June 17, 2011, 04:15:17 PM »
How to find out if a function AutoLisp this working?
CMDACTIVE does not show it.
Re: AutoLisp this working?
« Reply #1 on: June 17, 2011, 05:39:31 PM »
From the help file.
Indicates whether an ordinary command, transparent command, script, or dialog box is active. The setting is stored as a bitcode using the sum of the following values:
1 Ordinary command is active
2 Ordinary command and a transparent command are active
4 Script is active
8 Dialog box is active
16 DDE is active
32 AutoLISP is active (only visible to an ObjectARX-defined command)
64 ObjectARX command is active
Try something like this:
(= (logand (getvar "cmdactive") 32) 32)or this
(= (logand (getvar "cmdactive") 16) 16)
velasquez
« Reply #2 on: June 18, 2011, 08:48:26 AM »
From the help file.
4 Script is active
16 DDE is active
Thanks Cab,
The AutoLISP function waits for a response but returns CMDACTIVE is 0.
« Reply #3 on: June 18, 2011, 08:54:16 AM »
Perhaps?
(defun c:test nil
  (if *lisp-reactor*
    (progn (vlr-remove *lisp-reactor*) (setq *lisp-reactor* nil))
    (setq *lisp-reactor* (vlr-lisp-reactor nil '((:vlr-lispwillstart . lispcallback))))
(defun lispcallback ( reactor params )
  (princ "\n--> LISP is Running.")
velasquez
« Reply #4 on: June 19, 2011, 10:11:21 AM »
Perhaps?
(defun c:test nil
  (if *lisp-reactor*
Thank you for your code Lee
