Author Topic: Wheel button  (Read 3200 times)
VerticalMojo
Wheel button
« on: January 10, 2005, 05:35:57 PM »
Holding my middle wheel button down I can pan my drawing.... and if I scroll the wheel button I can USALLY zoom in and out. But There is some instances that it pans the drawing up and down..... Can someone explain why it’s doing this and how I can set it to zoom only?
Thanks!
Wheel button
« Reply #1 on: January 10, 2005, 05:50:48 PM »
It is a known issue with Windows and other programs that have internal scoll mouse handlers.....
In the Control panel, select the scroll mouse and then go to the troubleshooter ... finally select the AutoCAD software and it will put it in the list of software to turn off the default Windows scroll mouse handler ... you must have the driver for the mouse installed otherwise you will not have the option to disable the windows driver in AutoCAD
dubb
Wheel button
« Reply #2 on: January 10, 2005, 06:22:22 PM »
try
mbuttonpan
set it to zero
and check to make sure your mouse properties is microsoft wheel compatible in your mouse control panel.
Dent Cermak
Wheel button
« Reply #3 on: January 10, 2005, 06:45:06 PM »
that sets the osnap menu only.
dubb
Wheel button
« Reply #4 on: January 10, 2005, 07:47:51 PM »
O..i must have misunderstood that..btw..my mubottonpan is always zero.
Bob
Wheel button
« Reply #5 on: January 11, 2005, 03:20:05 AM »
If it happens to me I hold down the ctrl button at the same time as scrolling the button
hudster
Wheel button
« Reply #6 on: January 11, 2005, 03:44:46 AM »
do you by any chance still have the "Display scroll bars in drawing window" option enabled?
Mine used to do this till I unselected it.
VerticalMojo
Wheel button
« Reply #7 on: January 11, 2005, 09:38:01 AM »
Quote from: Keith
I guess I dont have it installed... maybe thats a XP thing? It didnt give me the option to add AutoCAD.
Quote from: Bob
Wow very nice... sounds like an easy fix  :)
Quote from: Hudster
I should take them out since I have the pan button....
VerticalMojo
Wheel button
« Reply #8 on: January 11, 2005, 09:40:45 AM »
Quote from: Hudster
Instead of scrolling or zooming it dosent do anything.....  :?
AfricaAD
Wheel button
« Reply #9 on: January 11, 2005, 01:00:22 PM »
I have the MS Intellipoint Optical using the 5.2 drivers. How come there is a delay or I have to hit the scroll button twice in order to pan? Is there a fix or a way to speed this up? I have it set as a middle click in the mouse properties for AutoCAD.
tcdan
Wheel button
« Reply #10 on: May 26, 2005, 03:51:08 PM »
I'm glad to know I'm not the only one who has had this problem. . . a friend here at work came up with a crazy temporary solution.  Whenever the mouse wheel would start making the screen pan, he would put his mouse arrow in the square at the ends of the display scroll bars in the drawing window (open up CAD and if you have these scroll bars displayed you will see the little square).  He would scroll the mouse wheel a few times, and - TADA - it would zoom in the drawing again.  Weird, huh?  You should try this technique out sometime if the problem happens again.
mbuttonpan isn't the problem - this variable turns on/off panning when you press down on the mouse wheel button, not when you scroll with the mouse wheel.
THE REAL SOLUTION:
Yeah - this solved the problem for me.  Thanks Keith!
tcdan
Wheel button
« Reply #11 on: May 26, 2005, 03:52:18 PM »
HURRAH FOR MY FIRST POST EVER!
Wheel button
« Reply #12 on: May 26, 2005, 03:54:46 PM »
Quote from: tcdan
That'd be your SECOND post ... oh .. and you are welcome :)
