Hello all,
this is my first post here.
I live in Germany and i hope my English is not to bad.
I use lisp since a long time and solved some problems in autocad with it.
I found Superflatten 1.1a anywhere a few months ago and after some checks i mention that it is the best program around.
Thank you Joe for this exceptional program.
Now i noticed, that there is a new release 1.2e. I inspected the code and made some tests with drawings in autocad.
I fixed some lines for use in local autocad versions and added an error control in function "FlatRegion".
You find the lines marked as:
;; *** Modification by pb
My test drawing "Pumpe1.dwg" contains one 3DSOLID. With my changes superflatten processes without any error but leaves some objects unflattened.
The other point is, that some flattended parts have lost details (for instance border lines).
(AutoCAD 2009)
Hope, somebody can give a suggestion.
kind regards
Peter B.
