Author Topic: Problem with some regions exploded from 3d-bodys processed with Superflatten  (Read 13496 times)
peterba
Joe,
glad to see your new program version, but today I collect my stuff for winter holidays and will try your program later after 3 weeks.  :oops:
Peter.
chlh_jd
Hi ,
What about flatten by this way !
(defun C:3d2d (/ laylst d lay ss)
  ;;by GSLS(SS)
  ;;error handing
  (defun ss-errexit (msg)
    (command)
    (command)
    (if (or (= msg "Function cancelled")
    (= msg "quit / exit abort")
      (princ msg)
      (princ (strcat "\n错误: " msg))
    (clos)
  (svos)
  (vl-catch-all-apply
    'vl-cmdf
    (list "UCS" "N" "V" "" "LAYOUT" "N" "Test" "")
  (setvar "CTAB" "Test")
  (setq ss (ssget "x"))
  (vl-catch-all-apply
    'vl-cmdf
    (list "ERASE" ss "" "MVIEW" "F" "" "MSPACE" "")
  (if (not SolProf_bak)
      (setq SolProf_bak T)
      (vl-catch-all-apply
'vl-cmdf
(list "SolProf" ss "" "Y" "Y" "N")
    (SolProf ss "" "Y" "Y" "N")
  (while (setq d (tblnext "LAYER" (null d)))
    (setq laylst (cons (cdr (assoc 2 d)) laylst))
  (setq lay (last (vl-remove-if-not
    (function (lambda (x)
(wcmatch x "PV*")
    laylst
  (setvar "CTAB" "Model")
  (vl-cmdf "UCS" "N" "V" "")
  (setq ss (ssget "x" (list (cons 8 lay))))
  (vl-file-delete "C:\\TEST.DWG")
  (vl-cmdf "wblock" "c:\\TEST.dwg" "" '(0 0 0) ss "");_here , you can change into another acad saving method .
  (foreach a laylst
    (if (wcmatch a "P[VH]-*")
      (vl-cmdf "ERASE" (ssget "X" (list (cons 8 a))) "")
  (vl-catch-all-apply
    'vl-cmdf
    (list "layout" "D" "TEST" "" "UCS" "W" "")
  (vl-Catch-All-Apply
    '(lambda ()
       (vla-Remove
(vla-GetExtensionDictionary
   (vla-Get-Layers
     (vla-Get-ActiveDocument
       (vlax-Get-Acad-Object)
"ACAD_LAYERFILTERS"
  (command "_.PURGE" "a" "*" "N")
  (clos)
(princ "/n高山流水3D实体Hidden线框转2D线框程序,命令3D2D")
;; save old sysvar
(defun svos ()
  (setq #system#    '("OSMODE"      "ORTHOMODE"    "CLAYER"
      "CECOLOR"      "PLINEWID"     "CELTYPE"
      "CMDECHO"      "ELEVATION"    "PICKSTYLE"
#vlale#     (mapcar 'getvar #system#)
gsls_olderr *error*
*error*     ss-errexit
  (vla-startundomark
;; call old sysvar
(defun clos ()
  (vla-EndUndoMark
    (vla-get-ActiveDocument (vlax-get-acad-object))
  (MapCar 'setvar #system# #vlale#)
  (setq *error* gsls_olderr)
Joe Burke
Joe,
Peter.
Peter,
I look forward to your comments when you have time to test the new SF 2.0a beta version.
I hope you'll find it's faster and more reliable than using ExpressTools functions.
I decided not to offer an option at the command line to use explode on 3DSolid and similar object types. WMFOutIn is used, assuming ACAD 2005 or later.
BTW, the code which deals object types other than things like 3DSolids and similar is not changed. So users of previous SF versions should get the same results with the new code.
Regards
« Last Edit: February 27, 2011, 06:27:51 AM by Joe Burke »
Joe Burke
Hi ,
I'm not sure what this code is designed to do. Maybe provide an example file?
chlh_jd
Hi Joe,
It just get 3dsolid hidden frame .
Joe Burke
Hi Joe,
I'm not familiar with a 3DSolid hidden frame. Is it something I should consider within the latest SuperFlatten code which deals with the 3DSolid object type?
