Author Topic: Upgrade VS project to x64 ?  (Read 7525 times)
LE3
« on: July 17, 2010, 04:51:08 PM »
I have a visual studio C# project, that runs in win32 AutoCAD 2010 (A2007,8,9) and now got the chance to do the upgrade
to x64 (have now a x64 system with AutoCAD 2010 installed to run my tests).
I do not see anywhere the reference COM "AutoCAD/ObjectDBX/Common XX Type Library" (I have on my project this one: AutoCAD/ObjectDBX/Common 18 Type Library)
I see under: D:\ObjectARX 2010\inc-x64 two .tbl files ( axdb18enu.tlb acax18ENU.tlb) and the same ones here: C:\Program Files\Common Files\Autodesk Shared
Totally confused, have tried to add both tbl files, also these ones: Autodesk.AutoCAD.Interop.dll Autodesk.AutoCAD.Interop.Common.dll (under D:\ObjectARX 2010\inc-x64)
and appear that I don't have any luck...
What do you guys do?
Thanks!
David Hall
  • Automatic Duh Generator
Re: Upgrade VS project to x64 ?
« Reply #1 on: July 17, 2010, 07:00:21 PM »
Luis wouldn't you need to reference the 64x version of acdbmgd and acmgd.DLL?
LE3
« Reply #2 on: July 17, 2010, 07:09:29 PM »
Yes, I have those (I assume that those two assemblies are x64, since my laptop is 64 bits... or? )- but my code that works on win32 does not display one of the dialogs....
Here it is a snapshot of my references... if helps in any way:
« Reply #3 on: July 17, 2010, 08:38:19 PM »
No, programmers should always reference the managed DLLs that come with the ARX SDK, usually in the \inc folder. These DLLS are specifically designed for this purpose
LE3
« Reply #4 on: July 17, 2010, 08:44:45 PM »
I use those (noticed the capital letters that means were referenced from the sdk...), and also tried the ones from where acad it is installed... no worky in my case.... should I register the x64 tbl's so it can be (maybe) avail in the com tab?
« Reply #5 on: July 17, 2010, 08:52:28 PM »
Oops sorry, I should have read your post all the way through, you would think those would have been installed with Acad. I'd do a repair of the install
.. let me check mine
« Reply #6 on: July 17, 2010, 08:58:10 PM »
Don't know LE, its not on mine either  :-o
LE3
« Reply #7 on: July 17, 2010, 09:05:49 PM »
will try to register the tlb and see what happens (it is inside of ObjectARX 2010\inc-x64).
« Reply #8 on: July 17, 2010, 09:31:20 PM »
flying past, haven't read the whole thread
does this piccy help
LE3
« Reply #9 on: July 17, 2010, 09:44:23 PM »
I have use that one, will double check and try again... have you used that in any of your x64 code?
« Reply #10 on: July 17, 2010, 09:50:40 PM »
Haven't done any COM stuff on 64bit yet Luis
LE3
« Reply #11 on: July 17, 2010, 09:57:02 PM »
Thank you Kerry.
I just added the assembly (from SDK 2010) and does not work.... for me.
« Reply #12 on: July 17, 2010, 11:13:45 PM »
Luis,
Can you clarify what you mean by 'does not work' ??
Which OS are you using ?
What ActiveX Types and Methods are you trying to access ?
LE3
« Reply #13 on: July 17, 2010, 11:31:17 PM »
Microsoft Windows NT Version 6.0 (x64)
Acadver: 18.0s (LMS Tech)
To give you an idea, was thinking to try/move/use simple .net instead of those COM calls/usage... will give it a try
public static Node SelectEntityProperty(bool bSelect)
try
if (CXCELClass.gCReportTemplate != null && CXCELClass.gCReportTemplate.gfrmReport != null &&
!CXCELClass.gCReportTemplate.gfrmReport.IsDisposed)
CXCELClass.gCReportTemplate.gfrmReport.Visible = false;
#if !COM_APP
if (doc == null)
System.Windows.Forms.MessageBox.Show("No opened drawing found.", "Error finding drawing.",
System.Windows.Forms.MessageBoxButtons.OK, System.Windows.Forms.MessageBoxIcon.Exclamation);
return null;
Editor ed = doc.Editor;
Object ObjEnt;
AcadApplication acAppCOMObj = Application.AcadApplication as AcadApplication;
//Microsoft.VisualBasic.Interaction.AppActivate(Application.MainWindow.Text);
// Ask the user to select an entity
PromptEntityOptions opt = new PromptEntityOptions("\nSelect entity: ");
PromptEntityResult res;
while ((res = ed.GetEntity(opt)).Status != PromptStatus.OK){
if (res.Status == PromptStatus.Cancel)
return(null);
ed.WriteMessage("\nCommand: ");
Transaction tr = doc.TransactionManager.StartTransaction();
using (tr)
DBObject obj = tr.GetObject(res.ObjectId, OpenMode.ForRead);
ObjEnt = acAppCOMObj.ActiveDocument.HandleToObject(obj.Handle.ToString());
tr.Commit();
Node nod = new Node();
frmObjProp frm = new frmObjProp(bSelect);
CadxcelNET.CXCELClass.GetMainForm().frmPropExplorer = frm;
frm.treeObjProp.Nodes.Add(nod);
SetDatPropObj(ObjEnt, nod);
nod.Expand();
frm.ShowDialog();
if (frm.DialogResult == System.Windows.Forms.DialogResult.OK)
return frm.treeObjProp.SelectedNode;
else
return null;
#else
AcadDocument acDocCOMObj;
Object objEnt = null;
Object objPoint;
string strRes = "Yes";
if (acAppCOMObj != null)
acDocCOMObj = acAppCOMObj.ActiveDocument;
//Microsoft.VisualBasic.Interaction.AppActivate(acAppCOMObj.Caption);
while (objEnt == null && strRes.CompareTo("Yes") == 0)
try
acDocCOMObj.Utility.GetEntity(out objEnt, out objPoint, "\nSelect Entity:");
catch
acDocCOMObj.Utility.InitializeUserInput(1, "Yes No");
strRes = acDocCOMObj.Utility.GetKeyword("Nothing selected. Continue?(Yes/No):");
if (objEnt == null)
return(null);
frmObjProp frm = new frmObjProp(true);
SetDatPropObj(objEnt, nod);
nod.Expand();
frm.ShowDialog();
else
return null;
#endif
catch{}
CXCELClass.gCReportTemplate.gfrmReport.Visible = true;
return null;
sinc
« Reply #14 on: July 18, 2010, 01:50:46 AM »
There is no "64x version" of the managed libraries.
One of the neat things about working with .NET is that the CIL is independent of the underlying architecture.  So as long as you aren't trying to reference the Interops and use COM stuff, and as long as you aren't doing any PInvoke stuff, you can pretty much ignore x86 vs. x64.
