I have a visual studio C# project, that runs in win32 AutoCAD 2010 (A2007,8,9) and now got the chance to do the upgrade
to x64 (have now a x64 system with AutoCAD 2010 installed to run my tests).
I do not see anywhere the reference COM "AutoCAD/ObjectDBX/Common XX Type Library" (I have on my project this one: AutoCAD/ObjectDBX/Common 18 Type Library)
I see under: D:\ObjectARX 2010\inc-x64 two .tbl files ( axdb18enu.tlb acax18ENU.tlb) and the same ones here: C:\Program Files\Common Files\Autodesk Shared
Totally confused, have tried to add both tbl files, also these ones: Autodesk.AutoCAD.Interop.dll Autodesk.AutoCAD.Interop.Common.dll (under D:\ObjectARX 2010\inc-x64)
and appear that I don't have any luck...
What do you guys do?
Thanks!
